servo resolution question . . .
I'm playing with standard R/C servos (1-2ms input pulse width). The following code starts it in the neutral position, and each button push bumps the input pulse up or down by a usec. It ends up taking a few pushes to have the servo move. Seems that, although I've got 1000 ua steps from 1 to 2, the resolution of the servo is less. Looking at various servo specs, I don't see that stated anywhere. Since I'm using it to move a laser pointer over tens of feet, I'd like to get as tight a delta as possible. The units I'm using are a couple Futaba S3003's and a Thunder S-15. Any insight?
TIA
Don
TIA
Don
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
long servoStack[50]
long servoDwell
OBJ
ser : "fullduplexserial"
PUB startups | debounce
ser.start(-1, 25, 0, 9600)
servoDwell := 1500 ' microseconds
cognew( servo, @servoStack )
dira[18]~ ' button
dira[22]~ ' button
repeat
debounce~
if ina[18] ' CCW
servoDwell += 1
servoDwell #>= 950
ser.tx( 12 )
ser.dec( servoDwell )
repeat
if not ina[18]
debounce++
else
debounce~
until debounce => 1000
debounce~
if ina[22] ' CW
servoDwell -= 1
servoDwell <#= 1950
ser.tx( 12 )
repeat
if not ina[22]
debounce++
else
debounce~
PRI servo
dira[23]~~ ' LED
dira[15]~~ ' servo control
repeat
outa[15]~~
outa[23]~~
waitcnt( cnt + clkfreq / 1_000_000 * servoDwell )
outa[15]~
outa[23]~
waitcnt( cnt + clkfreq / 1_000 * 10 ) ' ms
keep the questions coming
best regards
Stefan
Openservo is another interesting project.
-Ron
