Keypad with shift resisters
Can someone tell me where to find information on how to wire a 4x4 Matrix Keypad with shift resisters
and how to code it for a BSpx . Thanks Carl
Apparently we can connect two shift resisters together and read 16 buttons with one pin, maybe this is what he wants?
I wanted to make a custom keyboard configuration, and thought I might try to read 108 buttons using a single pin. The idea was to use bare solder pads like on the quickstart board, but I didn't get past figuring out which parts would work.
Would shift registers work with quickstart - type "Pad buttons"? Could eight such buttons be read with a single pin?
Could larger and/or multiple shift registers be used to read lots of buttons, say over 100?
The question here was about a 4 x 4 keypad which consists of 16 keys arranged in a matrix format to be scanned using 4 + 4 = 8 I/O pins, usually 4 inputs and 4 outputs. This could be done with an 8-pin I/O Expander, but not with ordinary shift registers. Larger keyboards (like your 108 keys) are typically scanned in the same fashion. You might use 14 outputs and 8 inputs. The outputs could be handled with a pair of serial to parallel shift registers like the 74HC595 and the inputs could be handled with a parallel to serial shift register like the 74HC165 or you could use a 16-bit I/O expander plus an 8-bit I/O expander.
You could use I/O Expanders to handle something like the QuickStart's pad buttons. In this case, you have to switch between input mode and output mode fairly quickly and you can't really do that with the shift registers.
Carl
Carl
