Powering up the QuickStart
I'm a little confused on how applying power/programming thru the USB works.
If I have an external power source lets say 9V going to VIN. I know the on board regulator will bring that down to 3.3V. Do I need to disconnect my 9V source before I reprogram the board with a USB cable.
Can I leave the Quickstart connected to my USB and use an external source?
Paul
Paul
I saw that on the schematic and on specs they do talk about the USB enable. Just didnt understand how this worked.
@Mike
If the voltage dips down below 4.3V. What would happen? You said this could be a problem, how? I plan to use a 2S LiPo pack so the voltage would never get that low so I'm really not concerned just curious with out doing an experiment that could damage my only board.
Thanks for reply guys.
Paul
If there is any possibility that the external source might fall below the minimum at any time, then you must use a diode in series with the external source into the VIN pin to protect against any back-flow. This would be the preferred method when powering the board from an external source, and is the safest.
It's important to note that USB power supplies are very commonly not limited/protected. They typically will have an overload shutoff switch, but it's not something you want to rely on. And most of the time they are tolerant of much higher current draw than the 500mA typical "max". That is why it is very important to protect against back-flow current into your external source. The USB won't necessarily be limited to 500mA, and may very happily provide enough current (i.e. wattage) to damage components on the QuickStart or your external VIN supply.
Also, the FTDI chip will not regulate USB power either. As far as the FTDI chip is concerned it's just a software request for so many "units" of power. If the computer or USB hub grants the request, then it will drive the pin low and turn on the MOSFET (Q2) which enables power to the rest of the board. But it's sort of an honor system on the part of the system designer that the amount of power drawn does not exceed the number of units requested. The USB hub can limit to exactly the much current, but often allows much more.
P(dissipated)=V(dropped across the regulator)*I(supplied to the rest of the circuit)
So VIN can have a wide range, but care must be exercised to ensure that the maximum power dissipated at the given operating temperature is not exceeded.
component.diode := true; # add diode for protection :thumb:
Okay, y'all can stop laughing now!!
— David Carrier
Parallax Inc.
I'm good to go now, I do know how to tell my anode from a cathode!
Also, in this case, you can probably go with just about any diode that will tolerate your required current. Often we will choose a Shottky because they have a fairly low forward voltage drop (and remember the power dissipated equals the voltage drop times the current), so they tend to dissipate less power - therefore typically more efficient in general. In this particular case we are following the diode with a linear regulator (as opposed to a more efficient switcher); so I wouldn't worry much about the forward voltage drop of the diode (unless your very tight on the lower limit of minimum input voltage) because whatever power is not dissipated by the diode will ultimately end up being dissipated by the linear regulator. So essentially, whether it's a low forward voltage drop or a high forward voltage drop the efficiency will end up being the same.
So basically... just choose a diode that is decently over-rated for current so you won't have to worry about power dissipation being a limiting factor. Essentially what David said: "Any diode that can take the current and voltage you are supplying will work" :-)
The diode will take some of the work off the linear reg. You could also consider 2 or more series diodes to further reduce the work of the linear reg if the vin is high and the reg is running hot.
1) How does it work while the QS is powered by both the USB and the 6V battery pack if both powers are equals, both diodes will open and power will be 5+6V?
Real life example: The project is already On. I connect USB for programming and disconnect.
2) I will use switch-mode power regulators (Dimension Engineering's DE-SWADJ (up to 1A, 10W) for my stepper motor that will be powered by another battery pack,
and for my QS, the AnyVolt model (.5A adjustable from 2.6 to 14V).
My question si if I really gain power autonomy (and less heat) from using such power regulator in the Vin, compared to just using the onboard regulator (of course I am asking to your gutfeeling, unless you really know).
3) By the way, even if maybe I should start another thread for this, for making work my 4x20 parallax LCD with the QS, Parallax Support told me that I need to have a common ground (LCD and QS). It works now.
4) My tip about batteries: I found - for those who do not know - that not only rechargeable batteries have lower voltage, but - and it is a possible limitation for me here in the canadian winter - they have a limited duty temperature range in the cold. I do not remember, but lets say from 32F and up.
So, check this in your battery specsheets if necessary. That is why, sadly, I will stick to use-and-garbage ones.
Diodes do not "open" (like a valve) to pass current.
They simply conduct in one direction but not the other.
(Switches are said to open in order to "open" (break) the circuit.
That's the opposite of close (short) to connect the circuit)
The voltage on the common end of the connected diodes will be the
higher of the two inputs - less the forward voltage drop of the diode.
One of the stickier problems one will encounter with multiple power
sources is that when connecting or disconnection the voltage may
be adversely effected. Voltage spikes or dips can play havoc with
logic systems.
There are a lot of electronics self-study sites on the net.
This is a good one.
http://openbookproject.net//electricCircuits/DC/index.html
So if I understand what you are saying, all the time, either of the diodes will block?
So, unless I get a suggestion, I would put a diode on both sides, rely on the onboard regulator and turn off the device when using USB connection.
But for future reference or for who it may interest, I got a reply from Avago. They suggest me 2 devices: Their lowest power optocoupler (HCPL-4701)
Minimum input can be driven with as low a current as 40uA.
But they say: make sure that the pull-up resistor on the output is between 11 kohm to 16 kohm.
http://components.arrow.com/part/detail/41658625S9024946N7786
and a solid state relay, the ASSR-1411 (looks simple!)
"The minimum recommended drive current for the ASSR-1411 is 3mA in the data sheet. However, if the output load is just low power, you may be able to make the ASSR-1411 work at 1mA drive current."
But in both cases, I would need to investigate and I do not know any of the pullups in the camera.
Maybe I'll it give a try in the future, but look nice for power consumption.
Fast-forward a year later and I purchased the 2x16 Serial LCD Backlit with Speaker accessory. I couldn't get it to work. (The test mode worked but the sample spin file would not.)
I replaced the LCD with a new one. It didn't seem to work any better at first, same result.
I went back to basics and attempted to run one of the original LED/touch button demos and was successful. I tried the LCD demo again and was able to get it to run but only after changing the signal pin to anything but PIN 0, the sample spin file default.
Aha, so my PIN 0 is fried, perhaps. At least I know that I can use the USB cable and power the LCD with the sample program.
Now, I return to trying to power the QuickStart + LCD with the 9V battery. No luck. For some reason it's almost as if the (new) 9V battery can't power both devices. I review the specs for the LCD screen and it indicates 5V. Do I need to lower the voltage now in order to get the LCD to power correctly? Based upon your diode discussion earlier in this thread I'm guessing that this is the case.
I've got pin 40 on the QuickStart going to a breadboard that also attaches to the 9V battery's positive pole and the LCD's center pin. I've got pin 39 of the QuickStart going to a breadboard that also attaches to the 9V battery's ground and the LCD's ground pin. Pin 2 on the QuickStart connects to the signal pin on the LCD via the breadboard.
So if I do need to add a diode into the mix (to power this with a 9V battery) then where to I change things up? Thanks in advance.
Ultimately, I bought all this so that I could create a tennis ball cannon. It is important to my project that it can run independently without being plugged into a computer just to get power via the USB.
So, link the 2 grounds together.
Also, make shure you use in the software the pin that is in fact connected to the LCD.
I use a voltage regelator that creates 5V for the LCD and for the VIN of Quickstart.
I have put a diode between the regulator output and the VIN.
9V are good for very low current devices. An LCD with a backlight will likely drain a 9V pretty quickly. You also shouldn't run 5V devices from 9V (as you have found). I'm betting the 9V powered LCD burned out pin 0 on your QuickStart.
As EMHmark7 said, if you're going to use 9V you'll need a regulator to redece it to 5V. I recently purchased some of these regulators off ebay, they seem to work fine.
Those 500ma cell phone chargers just don't cut it when I want to power up a Quickstart with a bunch of stuff hooked to it easily.
Anyone else want a couple of these?
Jeff
I'll take two Jeff. Thanks for offering this, and let me know how to pay you.
Great idea, but I've got it covered pretty well already.
My wall wart(s) are from an old network modem and router.
One +5 regulated (3 amps) and one +12 regulated (2 amps).
They were a buck each.
Look around the electronics bins in the second-hand stores.
As a non native english speaking person, I wonder a bit about this phrase. Is it not a good thing if the charger not cut your QuickStart board when you power it up?
Anyway, Phone/Pad chargers are not limited to 500mA. Most have 1A..2A current output. This is also labeled on these cheap ones from China, but they often don't really bring more than 200..500mA.
Andy
The phrase is most likely from "cut the mustard", or not up to the job...
When you say the diode is "between" the regulator output and the VIN, I am guessing that you're suggesting that the diode is "inline" on the VIN side.
I used the 9V battery originally because the specifications indicated that the QuickStart would internally clip the voltage as necessary. I doubt if the LCD immediately drained the freshly-unwrapped battery that I tried during the troubleshooting phase.
Personally, I'd imagine that two resistors in series could cheaply reduce the nine volts to five volts at a fraction of the cost of the voltage regulator. But if the 9V doesn't have enough current to drive what appears to be a simple LCD then I can't imagine the voltage regulator circuit fairing any better.
That said, I'll try the 6V (4xAA) route and see if this is any better.
Fresh out of the wrapper.
http://en.wikipedia.org/wiki/Nine-volt_battery
Last night (LATE) playing around with my motor driver circuit I managed to have the battery and USB
cable both on at the same time. Looks like it blew out the hub, cuz the hub don't work no mo.
It was a cheapie, true, but I'm glad it was the hub and not the port in the computer!
Thanks guys.
Also, maybe you already know, the motor needs a diode protection against hihg current spikes it will do when its current is dropping, or when it is stopping.
