Zener Diod 1N4733A
I bought a few of these zener diodes (1N4733A) and have never used them. Can I use them to replace a few shottkey diodes as in this circuit?
The solar panels I am using are two 6V cells in series, the battery pack is 8 NiMh AA's. I don't have any Schotkey diodes on hand.
I will place a regular diode between the cells to prevent reverse voltage? the voltage to the board has an input voltage rating greater than what the cells can put out which is ~18V no load.
I've never used schottkey diodes either so sorry if this sounds like a dumb question.
The data sheet for this Zener Diode is http://www.alldatasheet.com/view.jsp?Searchword=1N4733A
Thanks for your help with this.
A zener has a forward voltage drop like any rectifier diode. It is different in that it will hold off current when reverse biased until the zener breakdown voltage is met where it will begin to conduct. And, they're leakier, too.
So, Schottky diodes aren't zener diodes only with different funny names.
I wouldn't do what you suggest. Someone may come along and tell you, "It's OK."
USB circuitry for Tiny85 uc's. I discovered that
for some reason the 1amp versions were cranky
and the 500ma lower rated parts worked much better.
Never bet the farm on them, get a TL431 or similar.
