a real PWM (= ontime 0%-100%) with just set and forget counters?
StefanL38
Hi counterexperts,
is it possible to configure the counter or maybe if using two counters to create an endless ongoing
(= not a pulsetrain) PWM-signal?
Setup 1/2 counter(s) f.e. 20% ontime and then "forget" it as the counter(s) are producing the PWM-signal
automatically without any additional repeated changing of counterregisters?
keep the answers coming
best regards
Stefan
best regards
Stefan
You setup 2 counters each one is driving one pin. You then connect the pins with an XOR. (The output of the XOR is then the PWM signal.)
Both pins in sync will give you 0%, both pins generating the exact opposite signal give you 100%. Each value in between will give you a value in between and is equivalent to the phase-shift.
Right???
http://obex.parallax.com/objects/668/
thank you very much for pointing to the different solutions.
best regards
Stefan
