Looking For A Stop Watch Object With Floating Point Support — Parallax Forums
idbruceidbruce Posts: 6,197
edited 2011-08-14 00:54 in Propeller 1
Hello Everyone
Does anyone know of an existing object that can be used as a stop watch for code execution and includes floating point support?
Thanks in advance.
Bruce
    edited 2011-08-13 12:52
    That's a very vague description of what you want Bruce. Time generally does not come in floating point. Do elaborate.
  • idbruceidbruce Posts: 6,197
    edited 2011-08-13 13:23
    Heater
    I was going to try and represent my idea with code, but I think a description would be much simpler.
    My main product line includes six different sizes. To make the product for a specific size, a block of code is executed with a specified set of variables. To execute this block of code, there is an elapsed time from start to finish, and it is elapsed time that I want to measure. However, instead of a result that ends 5 seconds and 3 milliseconds, I want a result of 5.003 seconds to display on a LCD.
    Bruce
    edited 2011-08-13 13:30
    if you measure milliseconds I think it is quite easy without floating point
    all calculatins are done in milliseconds.
    seconds := All_The_milliseconds / 1000
    milliseconds := seconds // 1000 (modulus operator)
    lcd.dec (seconds)
    lcd.tx(".")
    lcd.dec(millisecond)
    keep the questions coming
    best regards
    Stefan
    edited 2011-08-13 13:47
    StefanL38
    Well that was a pretty fast and decent solution. Thanks Stefan. I apologize for getting upset with you a couple weeks ago. Sorry.
    Bruce
    edited 2011-08-13 13:55
    The technique Stefan used is often referred to as pseudo real. I've read about it in several of Parallax's books (I don't remember which ones anymore).
    Duane
    Edit: It's called pseudo real not pseudo random.
    edited 2011-08-13 13:58
    There is something written about it in PE Kit Labs V1.2 for timekeeping applications. But after first glance it did not appear that it would do what I wanted. However, after seeing Stefans code, it became crystal clear :)
  • AribaAriba Posts: 2,694
    edited 2011-08-13 14:51
    idbruce wrote: »
    ... a result that ends 5 seconds and 3 milliseconds, I want a result of 5.003 seconds to display on a LCD.
    Stefans code will show 5.3 and not 5.003 in this case. You can calculate every decimal place separatly to get the correct result:
    lcd.dec(milliseconds/1000)
      lcd.tx(".")
      lcd.dec(milliseconds/100//10)
      lcd.dec(milliseconds/10//10)
      lcd.dec(milliseconds//10)
    But I''ve seen dec-methodes with an additional dec-point several times in this forum, just don't find it now.
    Andy
    edited 2011-08-13 15:36
    Thanks Andy, very much appreciated.
    Hi Ariba,
    thanks for clearing up this.
    This is the difference between quick and dirty just writing code and carefully having tested code.
    keep the corrections coming
    best regards
    Stefan
