Solar Proto: What to do with the Parallax 2.5W solar cell (todays $7.49 DotD) ?? — Parallax Forums
TubularTubular Posts: 4,771
edited 2011-08-13 12:16 in Propeller 1
Want to know what to do with the 2.5W solar cell (the $7.49 deal of the day)??
The LTC3108 from Linear technology harvests energy from sources as low as 20mV. It can be used with a single solar cell such as the parallax one on special today, and can even harvest energy from the fluoro's in your office to trickle charge up a supercap.
... you'll also need
* Parallax 2.5 Watt single cell (today!)
* LTC3108 from Linear technology (a few$)
* TSSOP16 breakout (eg Futurlec.com)
* Coilcraft 1:20 stepup transformer as per LTC3108 datasheet ($1.06)
* CAP-XX supercap
* Blank proto board
* MCP3208 (optional) for monitoring)
* The plywood packaging the Parallax cell comes in
* Drawer handle!
The LTC3108 charging power path is only about 4.5mA, but it can charge any size supercap, or 4.1 volt Li-ion/Lipo batteries. These can in turn provide much higher currents but at a lower duty cycle.
This was all inspired by Beau's mppt comp. Then I realized this really has very little in common with maximizing efficiency - in fact its terrible as far as efficiency goes!
cheers
tubular
Post Edited (Tubular) : 7/7/2010 11:44:07 PM GMT
