finding capacitor polarity — Parallax Forums
agimuhingagimuhing Posts: 39
edited 2011-08-11 15:56 in General Discussion
I got this capacitor from a grab bag
<- the pin on the left has a polarity marking
appears to be electrolytic because there is a can inside the casing
also has a black polarity marking above one of the pins
But is the marked pin positive or negative?
the cap also appears to be surface mount, but I've never seen a package like this before
What device might this be found in?
    edited 2011-08-11 08:41
    Ummm... Yes! :zombie:
    Some electrolytics noted Pos and others noted Neg.
    I don't think I've ever seen a tantalum marked other than Pos.
    edited 2011-08-11 09:57
    Are you sure it's a cap? Aside from the markings, it looks more like a crystal.
  • agimuhingagimuhing Posts: 39
    edited 2011-08-11 13:41
    I hooked it up to a multimeter measuring resistance, and the capacitor/crystal/mystery component's resistance slowly increased to infinity. I don't think crystals do that.
    Also, the increase to infinity was faster when the cap was hooked up to the multimeter in a certain direction.
    edited 2011-08-11 13:45
    Flux capacitor? :)
    It does sound like an electrolytic from your multimeter test. Dunno how to tell polarity. Make sure it was fully discharged for your multimeter timimg tests.
    edited 2011-08-11 14:06
    I know that capacitors have leakage. Electro caps have more leakage when installed backward. My dad said that he was able to tell the polarity of a cap by hooking it up to an analog multimeter and measuring its resistance. The problem is my multimeter is digital and doesn't do that very well
    edited 2011-08-11 14:15
    http://www.physicsforums.com/showthread.php?t=99017
    reply #2 agrees with agimuhing. multimeter infinite resistance connection shows correct polarity, wrong polarity shows leakage (finite high resistance)
    edited 2011-08-11 14:28
    my multimeter shows infinite resistance both ways the capacitor is connected.
    time to find an amp unless someone else has a solution
    edited 2011-08-11 15:09
    I know this sounds bad but blow one up !
    it it go BOOOM then its the wrong way .........
    Peter
    edited 2011-08-11 15:11
    Sure Peter, then just press the UNDO button... :)
    agimuhing wrote: »
    Depending on the impedance of your meter, and if the "100" on the device means 100 microfarad, you may have to keep it connected a while before you start seeing anything.
    An analog meter is the better tool for this. You can still find them, especially used.
    -- Gordon
