Can a dual Lo side mosfet driver; drive (2) N Mosfets in a half bridge configuration?
Capt. Quirk
I recently purchased some Fairchild dual low mosfet drivers. At the time I thought Lo meant n-mosfet. I have looked at the specs for similar Hi side drivers,
and the specs doesn't make any sense to me despite a illustration showing two n mosfets.
Any help would be appreciated
Bill M.
Bill M.
I don't completely understand, but I will take what you said, and work it out.
Bill Mazzacane
The idea is that you apply the gate signal through the opto-isolator, whose transistor is connected to the 9 volt battery and logic supply in series. It boosts the 5V gate voltage by another 9 volts, without a charge pump circuit. For $1 in parts, including the battery, it's a workable alternative.
As PJ sez in his other thread, designing and building bridge bridge circuits, at least those that are efficient and not prone to burning out, is no walk in the park.
-- Gordon
You can certainly put a pMOSFET in the high side. There's still the issue of gate drive, though, since the gate must then be at the load's supply potential to turn the pMOSFET off. How complicated this needs to be depends on how fast you need to turn the gate on and off.
Not exactly. The optos are gating Q1/Q3, and the motor V+ is going through those. At least that's how I read his schematic.
As Phil sez, it's important to get the timings right here, or you stand to have all four transistors on at the same time for very brief periods of time. Timing is less of a problem if you're steering the logic to the four gates via a Prop or other microcontroller, where you can easily control when the gates are turned on.
And yeah, what Phil says about gating the low side for PWM, at least if you want to get the PWM period out of the low hearing range.
-- Gordon
+V (12V), a/k/a the "high-side", gets switched through Q1/Q3 (depending.)
Those transistors' gate voltage is switched/enabled through the optos (U1, U2 respectively.)
Q1 presents the motor with a +V and Q2 makes a current path for one direction.
Q3 presents the motor with a +V and Q4 makes a current path for the other direction.
PE -- A few days ago I updated the blog without mention in the subject here (in Projects.) I've been back working on the project that I'd started and interrupted to get on the H-Bridge track.
If you like, feel free to ask questions here or over at the h-bridge subject.
I have 2 computer monitors with multiple data sheets open on both screens---including all my notes
from previous questions, Photoshop open for dissecting data sheet graphs, and at least
3 data sheets and an app-note on my desk. After double checking my FDS6670a logic mosfets,
similar mosfets like the IRF3708, the low side mosfet driver, my new 1/2 H bridge mosfet driver, and
at least 2 other mosfet drivers, I came to this conclusion:
(1) If Battery voltage is greater than, my driver should work for a 1/2 bridge because it supplies
Battery Voltage + .3 vdc. to each FDS6670a mosfet.
(2) But for it to be reliable, I think, I would most likely need 24 to 30v batteries,supplying a 12volt r
egulator to supply my mosfet drivers so my speed control doesn't die after a 2v drop below RDS_on.
(3) I should just use a 555 and build a Lo side speed control, for my battery powered lawn mower.
Thanks for your help
Bill Mazzacane
