finding capacitor polarity
I got this capacitor from a grab bag
<- the pin on the left has a polarity marking
appears to be electrolytic because there is a can inside the casing
also has a black polarity marking above one of the pins
But is the marked pin positive or negative?
the cap also appears to be surface mount, but I've never seen a package like this before
What device might this be found in?
Ummm... Yes! :zombie:
Some electrolytics noted Pos and others noted Neg.
I don't think I've ever seen a tantalum marked other than Pos.
Also, the increase to infinity was faster when the cap was hooked up to the multimeter in a certain direction.
It does sound like an electrolytic from your multimeter test. Dunno how to tell polarity. Make sure it was fully discharged for your multimeter timimg tests.
reply #2 agrees with agimuhing. multimeter infinite resistance connection shows correct polarity, wrong polarity shows leakage (finite high resistance)
time to find an amp unless someone else has a solution
it it go BOOOM then its the wrong way .........
Peter
Depending on the impedance of your meter, and if the "100" on the device means 100 microfarad, you may have to keep it connected a while before you start seeing anything.
An analog meter is the better tool for this. You can still find them, especially used.
-- Gordon
