5v on the prop pins? — Parallax Forums
kutalinelucaskutalinelucas Posts: 80
edited 2011-08-14 08:51 in Propeller 1
Could anybody give me any ideas of the best way to interface a PIC18F and a propeller? I'm guessing the prop wouldn't be too happy with 5v on its pins!
I'm looking to communicate through a 2 way 4-bit data bus, so a voltage divider is out of the question. I have a 74LVC244AD line driver, but its surface mount and I'm on a breadboard, plus I haven't really looked into how to use it yet...
Cheers
  • RaymanRayman Posts: 16,276
    edited 2011-08-11 07:39
    I'd just try putting 10k resistors between PIC and Prop. 10k is enough to prevent damage to Prop.
    edited 2011-08-11 07:42
    The PIC18F has a sensible Vih of 2V or more even with a supply voltage of 5V (many have a Vih above 3.6V). This means that the Prop can talk to the PIC directly and all you need to do to keep the Prop happy when the PIC talks to it is to limit the current so the value of 10K that Ray mentioned is fine.
  • kutalinelucaskutalinelucas Posts: 80
    That simple?...fantastic, thankyou very much
    edited 2011-08-11 07:45
    Chris Savage wrote a great article about all your options in the April Nuts & Volts. Here's a thread discussing it:
    http://forums.parallax.com/showthread.php?130733-Did-any-one-read-the-article-in-Nuts-and-Volts-by-Chris-Savage-about-Mixing-Voltage&highlight=chris+savage+nuts+volts
    There's also some interfacing the Prop to "foreign" voltages in the sticky thread at the top of the forum:
    http://forums.parallax.com/showthread.php?111166-Propeller-HYDRA-Key-Thread-Index
    Of course, when you've done it with success, please come back and share your solution with all of us!!
  • agimuhingagimuhing Posts: 39
    edited 2011-08-11 07:49
    put a resistor between the prop rx pin and PIC tx pin
    (note: tx stands for transmit, rx stands for receive)
    prop rx pin <
    <PIC tx pin
    10K resistor
    the prop has internal clamping diodes to keep the voltage below 3.3V, the resistor is there to limit current going through the diodes
    check the PIC's logic high voltage, make sure it's less than 3.3V, then you can directly connect the prop tx pin with the PIC rx pin. A better idea would be to put another resistor between the pins to prevent damage caused by setting the pin states incorrectly (ie: PIC rx pin set to output high instead of input, and prop output low)
    prop tx pin>
    >PIC rx
    [/INDENT][/INDENT]10K
    resistor is
    optional, but a good idea
    you could also read this http://www.sparkfun.com/tutorials/65
  • WossnameWossname Posts: 174
    edited 2011-08-11 09:23
    Great thread, very useful to know. :)
    edited 2011-08-11 11:44
    Would the PIC part of the circuit be happy at 3.3 Volts ?? If so the drop that down and just bolt the two parts together dirrectly.
    just putting 10k resistors worked like a charm...cheers guys
