Micro SD card question
I have a Sandisk 2GB microSD card. Plugged into an adapter and then into a USB reader it only shows as 54MB on my computer. There aren't any files on the card.
What am I missing in understanding this? Shouldn't it show as 2GB space on my computer? It is formatted in FAT. I tried re-formatting it and it still is the same size.
Thanks.
Don
Thanks.
Don
When you formatted it did you do it the normal (slow) way or did you use "fast" format?
I've had trouble with SD cards that a normal format would fix but a fast format wouldn't.
Duane
The recommendation was to use the manufacturer's format utility when available.
The other recommendatin was to format the card in a peripheral device, like a camera or cell phone (but not a windows cell phone).
Also it seems that the first round of SD cards did not have a real standard and/or the manufacturers did not follow them consistently. This last turns out to not be a problem, since folks tended to dismiss the old cards as defective and toss them, so they are not so common anymore.
