Li-ion Power-Pack charger Solar
I am considering creating a small remote data logging station using the li-ion power pack as the power source. What I would like to do is have a solar cell(panel) attached to the station to be the input power for li-ion charger. Does Parallax have a matching solar panel for something like that, and they do not, will Parallax be selling something, soon? The docs mention that li-ion pack input requirements should be +5 - +12VDC @ 1amp. Since the solar panels are rated at a (w), I am not sure as to how figure out the amperage output for the solar panel.
Ray
Ray
The input power requirement for charging the Lion pack is a minimum of 5 volts. (It can be anything up to 12 vdc.). And the output voltage of the power pack is a nominal 7.2 vdc (at full charge it's 8.2 vdc).
So, how can a 5v source charge a 7.2v device? Simple: When in charging mode, the two 3.6 volt Lion cells are each charged individually. When the charging source is removed, the cells are connected in series automatically - download the Product Doc for more insight on this.
Our 30 watt solar Panel Kit has a nominal output of 6 volts with a maximum current of 5 amps, hence the 6 volt x 5 amp = 30 watt rating. This Panel can be the charging source (that's one of the first circuits that I put together myself). In fact, the Product Doc (for the Lion, in Fig 7) has an application note describing this exact circuit.
-Matt
I asked about the power requirements of your remote logger, because 30 watts might be overkill. Maybe you need to run other stuff from that power source too?
I really want to test out the xbee, since the above described setup will be approximately 100 to a 150 feet away from the house, and the base unit will be in the basement.
Yes, it can. It is completely sealed.
Short answer is no. (Besides, as Tracy says, it wouldn't run any 5 volt circuits)
And yes, the 30 watt solar panel is more than the charger requires.
However, I wasn't awake enough earlier when I posted my first reply - I thought (but apparently didn't type!) the answer to the question).
The Lion can be easily configured as a Un-interruptable Power Supply (UPS). That's the circuit that I was referring to in the Applications area of the Product Doc above.
Therefore, circuit operation would be as follows: When the Sun is shining, power is delivered to your circuit (by the Sun) while charging the cells as well. When the Sun no longer shines, power is then delivered to your circuit via the Lion cells.
Yes we do. However, by itself, it does not have enough amperage to operate the Lion Pack. You could connect several of these in parallel however, to get to the 1 amp minimum.
-Matt
-Matt
Yes, this is true. The only thing you really need to add is a couple of diodes and a capacitor (which essentially turns the Lion into a UPS), as outlined above. We purposely didn't include these simple components on the PCB, because their values would vary, depending on the application.
-Matt
