Per Mr. Parallax's Request - New Machine Photos
idbruce
Hello Everyone
Several years ago, I was content writing programs in Visual C++ and MFC, but then I discovered the BASIC Stamp and stepper motors. My life has not been the same since then, and I very rarely open Visual Studio anymore
Just a note for beginners:
Do more with those stepper motors than just watching them spin!
Here are a few photos of my new programmable label dispenser. This item will become part of my permanent product line, however one change will have to be made. It currently contains an OEM BASIC Stamp, which will be replaced in all future models by the Propeller chip. The width of the label will always remain constant, but any new length label can be programmed into the machine through the DB9.
Bruce, did you include a sensor to detect the gap between labels in order to avoid creep in the feed distance?
Bruce
It just so happens that I have done something similar in one of my projects. Can I suggest that the sensor is either fed into an ADC or that you PWM the LED and filter the output of the sensor so that your sensor can be controlled in software to distinguish the difference between the label or the tape automatically.
Please note that one item of particular interest is a G251 Gecko Drive stepper driver mounted as a daughter board of the Propeller Proto Board using the VGA mounting holes.
Machines like this one, only a little better built, retail from $500 - $800
Bruce
EDIT: This machine is also externally programmable through a DB9 connector
EDIT: Another item worth mentioning is that the Propeller Proto Board is being powered from the 5V logic supply from the main power supply in the enclosure. This feed is going directly to the 5V rail on the Proto Board, which feeds the 3.3V required by the Propeller chip.
I like the fact you have at least one of them decorating your living room. :-)
@Phil - What is the difference between a transmissive sensor and a reflective object sensor?
Frank
(isn't that what you wanted us to say, from your HV thread?)
Nice job. Good to see some metalwork here
I'm concerned about the metal strap holding the wall wart in place - it just doesn't seem to be far enough away from those (presumably 110v AC) pins. It could be just the angle of the photos, but that kind of jumped out at me... the heat from the box / wall wart would cause that AL strap to expand more than the plastic, permitting that angle about the single screw pivot to extend further, and then in a worst case scenario - could it touch those pins? What if the strap was put on backwards (180 degrees spun about), could it touch then?
I may be worrying unnecessarily. All the best with it.
@ElectricAye - And I also thank you for you comments
@Everyone else, new photos to be posted shortly!
Bruce
Here is a link to my wire bending and packaging CNC machines
http://forums.parallax.com/showthread.php?129612-My-Current-Prop-Based-CNC-Photos
And here is a link to an incomplete 3 axis CNC machine
http://forums.parallax.com/showthread.php?129621-Another-Propeller-Based-CNC-Machine-In-The-Works-Photos
And although posted elesewhere, somewhere in the forum, there are a few pics posted below of my UV exposure box for making PCBs.
All of the projects shown or linked to on this page have a Parallax uC or uCs embedded within them with the exception of the hot wire foam cutter, which will eventually have a Parallax product to maintain control.
Hope you all like my projects. Cheers.
Bruce
Bruce
Anyhow, thanks for the comment.
Bruce
