simple counting program
hello all, i'm just trying to write a simple program to count every time a pushbutton is pressed and show the number on a terminal screen, so basically the output would look like:
1
2
3
4
5
6
7
etc..
i'm using the parallax proto board usb, and i know how to do the hardware part of it. any help would be much apreciated thanks.
--Henry--
1
2
3
4
5
6
7
etc..
--Henry--
There should be tons of threads dealing with buttons. Search for button and maybe debounce.
You know that buttons are bouncing? Bouncing means that when pushed/released the electrical contact is not stable because the mechanics bounces back and forth for a short time. If you don't take this into account in your program, the counter would not increase in single steps but jump over several values with each push.
Counting and sending data to a terminal should not be a big problem, right?!
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PELabsFunBook-v1.1.pdf
Your code would then say something like
Repeat {forever} IF ina[22] == %1 {If button on pin 22 is pressed.} ButtonCounter := (ButtonCounter + 1) {Increment the counter by 1.} waitcnt(clkfreq/100 + clk) {Wait a little to debounce the button.} {Display ButtonCounter using whatever way you want to do it.}Go to the following page:
http://forums.parallax.com/showthread.php?89958-Propeller-Education-Kit-Labs-Tools-and-Applications
And look at the two sections under PE Kit Tools: PC Terminal Communication and there is Debug LITE for the Parallax Serial Terminal·. The serial terminal turns your computer into a display that allows you to debug SPIN code. I think the manual to which I linked earlier tells step by step how to set that up. In fact, that manual is a very good way to get started learning SPIN, etc.
I hope that helps get you started.
