Safe power for stamp project from 16/32 VAC transformer?
I have a keypad controlled door project. This will be the second one. The first one is in operation and working fine. For the first one I was able to repurpose a power supply from a broken DVD player.. it had a connector just like for a Hard Drive which I pulled the power from. It operated a 12VDC door latch.
Differences, this one will be to replace a commercial one which I would like to re-use some parts of. I want to use the door latch but this one is 24VDC. I would like to re-use the transformer supplied by 110 VAC and has both a 16 and a 32 VAC tap. I also have a large bridge rectifier from the old system I can use.
Given this as my supply... how can I safely connect the transformer to power my super carrier board with a BS2pe stamp?
My boards power everything on 5V except for a speaker/beeper and the latch. The latch for the 12VDC door was tripped by a 5VDC relay. Both the latch and the beeper were initiated through opto's.
I know the super carrier board itself can clean the signal up some, but rectified the 16V is still too high... what other precautions should I take?
Thank you,
Daniel
Thank you,
Daniel
The best answer would be to use a different power source for the Super Carrier Board using some kind of cheap "wall wart" that outputs 7V. If you really have to use the 16VAC transformer, put some kind of switching regulator between the DC output from the bridge rectifier and its filter capacitor and the Super Carrier Board's input. You can get a simple switching regulator from Dimension Engineering that'll do it.
On the BoE, the BS2 runs on "V_in".
On the Super Carrier, the BS2 (likewise the BS1) runs from VR1 ["V_dd"].
They are the same price. Which do you think would be a better fit? The first one has the full 24V but I worry if the tolerance is not good enough on it and the 5V line drops that it would not power the stamp, logger, RTC and things alright. The second one has a 5 and 12 I could cross for 7V if needed.. but does not have true 24V..although it does have enough current on both the 12V pos and 12V negative I think it would work to power the latch.
What are your thoughts? Looking forward to the input.
Thank you,
Daniel
Adjustable switching regulators are also available if you can't find a 9V unit, but these would be much more efficient than a linear regulator, develop much less heat and, cost a bit more than linear pieces.
I am not sure how to edit my posting to show it is solved?
Thank you.
Daniel
