Interfacing Propeller Chip to C#.Net
Hello:
I am looking for a tutorial on interfacing a propeller chip to a C# application. I am looking to turn a LED on/off from the c# application. A lot like the following Parallel Port example found at the link below.
http://www.codeproject.com/KB/cs/csppleds.aspx
Links and suggestions greatly appreciated.
http://www.agaverobotics.com/serialportdemo.zip
Serial port demo was originally written for Mono. It polls the serial port as the DataReceived event is not wired up in, at least in my version of, Mono.
He means this uterm which is improved to also work with linux: http://forums.parallax.com/attachment.php?attachmentid=81050&d=1305006212
