Can't get Parallax PING))) to work.
Hi, I'm a beginner in electronics, and I have recently hit a problem.
I bought the PING))) ultrasonic sensor, and I can't get it to work.
I have googled around the web and tried many different things, but nothing works. I'm using a PIC16F628 with the PING))) connected to pin nr. 4, and an LED connected to pin nr. 0.
I'm just trying to get the LED to lit up when it's getting a response from the PING))) and I think I've connected everything the right way, from the hardware's point of view, because when I replace the PING))) I/O pin (nr. 4 in my case) with another power source, the LED at pin nr. 0 lits up.
And the Activity LED on the sensor just lits up one tiny tiny moment, barely noticeable, when I'm powering on the circuit for the first time.
Is there any of you who have any experience with the PING))), and can help me?
Here's my code;
Here's my code;
;--------Initialize assembler
LIST P=PIC16F628 ; Telling the assembler what kind of microcontroller we are using
#include "P16f628.inc" ; Converting words to hex. values
__config 0x3f18 ; Settings, such as watchdog, internal timers, etc. All turned off
;---------Macros
bank0 macro
bcf STATUS,RP1
bcf STATUS,RP0 ; BANK0 (Data Memory)
endm
bank1 macro
bcf STATUS,RP1
bsf STATUS,RP0 ; BANK1 (Data Memory)
endm
bank2 macro
bsf STATUS,RP1
bcf STATUS,RP0 ; BANK2 (Data Memory)
endm
bank3 macro
bsf STATUS,RP1
bsf STATUS,RP0 ; BANK3 (Data Memory)
endm
;---------Registers
cblock 0x20
; Nothing for now...
endc
;---------Program memory
org 0x00 ; The beginning of the program
goto Start
org 0x04 ; Interrupt Service Routine
; Nothing for now....
;----------Main
Start ; Starting by setting all pins as outputs
bank1
movlw b'00000000' ; Pin 5 needs to be an input pin
movwf TRISA ; Set the inputs and outputs of port A
movlw b'00000000' ; All outputs
movwf TRISB ; Set the inputs and outputs of port B
bank0
goto SendSIG
PingOut ; Make pin nr. 4 an output pin for sending trigger signal
bank1
movlw b'00000000'
movwf TRISA
bank0
return
PingIn ; Make pin nr. 4 an input pin for retriving an echo signal
bank1
movlw b'00010000'
movwf TRISA
bank0
return
SendSIG
call PingOut
bsf PORTA,4 ; Trigger signal, 5uS long
call Delay5uS
bcf PORTA,4
goto ScanningSIG ; Trigger signal, now sent. Start listning for echo signal
ScanningSIG
call PingIn
ScanningLoop
btfsc PORTA,4 ; Check I/O pin
bsf PORTA,0 ; Light LED
goto ScanningLoop
;-----Delays---------------------------------------
Delay5uS ; A delay lasting for 5 micro seconds, including the "call"
goto $+1
return
;-----End------------------------------------------
Finish
end ; End of program
banksel PORTA
for instance.
You are setting PORTA to all outputs with
movlw b'00000000'
movwf TRISA
There are lots of problems with the code, as it's written. You'd be better off with a 16F88 as it has in-circuit debugging.
