Harvesting Gamma Radiation ?
Tubular
I just read an interesting article in the June Elektor, about using a blindfolded BPW34 photodiode to detect Gamma Radiation. The BPW34 is reverse biased and its charge amplified for viewing on a CRO. The BPW34 is covered with kitchen foil to prevent photon caused signals from overwhelming those due to gamma/beta radiation.
Having spent the day harvesting energy from various high impedance sources, I have to ask - what quantity (or ballpark qty) of energy is put out by each gamma impact event ?
Could this be harvested somehow?
http://www.technologyreview.com/blog/duncan/17611/
Also, you might have a look at this:
http://en.wikipedia.org/wiki/Orders_of_magnitude_(energy)
bon appetit
Iodine 125 ~ 35KeV
Cobalt 57 ~ 122KeV
Technetium 99 ~ 140KeV
Cesium 137 ~ 662Kev
One MeV (Million electron Volts) is 1.602x10 -13 Joules. It requires 1 J to heat one gram of dry, cool air by 1 degree Celsius. It would take a fair amount of radioactive material to produce a useable amount of energy.
Cosmic rays have a wider range of energies and using them for energy suffers from the same problems as solar energy. Converting gamma rays to energy requires expensive hardware and collectors that cover a large area.
Thanks kwinn. Some spacecraft convert energy from decaying sources, wonder how they do it.
I guess I should also post the links from the end of the Elektor article,
Maxim Application Note 2236
PIN photodiode-based X- and gamma-ray detectors, by Erhan Emirhan & Cenap S. Oezben
An Introduction to Semiconductor Radiation Detectors, by C.W.Thiel
Tubes,
they use one of these, which converts the heat byproduct, not the nuclear particles per se, into electricity:
http://en.wikipedia.org/wiki/Radioisotope_thermoelectric_generator
The thermoeletric generator in the link electricAye posted uses strontium-90, a beta (electron) emitter, and electrons are easier to capture within a self-contained device without thick layers of lead.
Another possible thermoelectric source is Americium, an alpha (proton, helium nucleus) emitter, and alpha particles do not travel very far at all in matter, even in air, before their energy is recaptured and turned to heat. A problem is, the element is relatively rare. There are several schemes to use Americium in space. (see the wiki).
You might think you could capture charge from the core of an ionization smoke detector, which contains about 1 microcurie of Americium-241. After all, one microcurie emits 37000 alpha particles per second. That might sound like a lot, except when you divide it by the amount of charge movement necessary to make an ampere, it comes out as 12 fA. That is 12E-15 A. The individual alpha particles that come off of Americium carry a lot of energy, about 4.5 million electron volts (compare to its occasional gamma ray at 60keV). A smoke detector works because those high energy highly charged particles have high probability of knocking electrons loose from atoms and molecules that they pass near. It takes 34 eV to ionize a molecule of air, so each high energy alpha particle leaves behind a track of over 100000 ionized air molecules. Multiply that times 37000 tracks per second, and there are a lot of ions floating around to act as charge carries. A 9V potential difference across the chamber that contains all of those charges yields a current that is a good fraction of a microamp.
As Dr Tracy Allen said "Gammas are relatively hard to capture" That is what fascinated me about this project. All the hand built boards, and custom IC's used for the project. Not to mention, how years work can be trashed by a gust of wind during before this UC Berkley balloon leaves the ground.
-> Dr Allen; I just noticed your location, were you involved with the UCB telescope?
bruce.banner@hulk.com
Tell him erco sent you.
Medical scans are primarily Technetium-99m, and in some cases Iodine125. Both are primarily gamma emitters, and it is the gamma that is used for imaging or being counted.
