Thanks Mike G — Parallax Forums
Thanks Mike G
MoskogMoskog Posts: 556
edited 2011-07-31 09:09 in Accessories
Thank you, Mike G for your awesome Spinneret tutorials. I find them very interesting and very helpful and look forward to more to come!
http://spinneret.servebeer.com:5000/index.htm
  • Mike GMike G Posts: 2,702
    edited 2011-07-29 17:39
    I'm happy to hear the tutorial is helpful :)
    I'm powering through the documentation for Sunday's deadline.
  • MoskogMoskog Posts: 556
    edited 2011-07-30 09:26
    Hi I'm not able to extract the httpserv.zip, I'm running win7 and message says there's something wrong with the folder itself.
    I'm not using an external unzip program, just using windows' own.
    Could you please check out that?
    edited 2011-07-30 12:43
    I'mnot sure what to check out. I can't reproduce the error. Anyway, I zipped the files with windows and not the Propeller Tool. See if that helps. Otherwise, grab the files from the Google Repository.
    http://code.google.com/p/spinneret-web-server/source/browse/#svn%2Ftrunk%2FMultiSocketServer_MikeG
    Found a solution, didn't work in win7 but no problem on my XP system.
    Win7 said the folder was empty, no files to extract.
    No comments from XP.
    Problem solved!
