Sestos Temperature Controller
I feel silly asking this but the DOCS are not the greatest with this product. Does the SestosD1S-2R-24 (dc controller) output a signal/voltage I can pass to the Prop to read the temperature. I am building a thermocouple device with 4 MAX 6675's to interface with the Prop but if these sestos controllers will do the trick it will save muco time with output display etc.
I am reading turbine egt, tit, tot and oil temp. for an FADEC turbine controller.
thanks for your help,
merdr47
merdr47
next post will be the docs.
thanks
sorry failure, this should work
with the construction of my MAX6675 (x4) board, more fun anyway. Thanks very much for your help
and I am sure I will be back with many more questions. This forum is so nice for a hacker like myself
(actually more of a slasher/banger) where I can go and get professional advice from knowledgeable souls... Thanks Again.
merdr47
