Counter question: how to set-up a counter to detect going from low to high?
I'm trying to figure out how to measure the time between the moment the code initiates an action (starts to move a servo) until a button is pushed and I was thinking that this would be a great job to use a counter for. I'm thinking that it would be very similar to the code used for seeing when a pin goes from high to low (documented in the PEK), only here I would need to know when the pin goes from low to high. I've looked through the manual, but I can't seem to get anything to work. Please let me know if you have any ideas or if you think there's a better way to do this, but I'm guessing/hoping there's a simple answer. Thanks!
Dave
Dave
I apologize for not responding sooner. Lots going on.
kwin,
Thanks for your suggestion. I would have liked to have gone that route, but the way the button (which is a tactile sensor with the center energized and the outer spring being the ground) requires the pin to go from low to high. Physically, this makes more sense and works great... except now I want to try and use the counter funtion.
kuroneko,
The example is found on pg 121-130 in v 1.1 that you can download here:
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PELabsFunBook-v1.1.pdf
and I'd like to reverse the condition, but it requires more knowledge than I have about how to set-up counters than what I have.
Anyhow, I'd love to hear any more thought's. Thanks!
Dave
CON pin = 16 PUB null | n ctra := constant(%0_01100_000 << 23 | pin) ' monitor pin for low frqa := 1 ' system clock resolution ' If pin reads low then the counter is already busy counting. ' This doesn't matter as we have a specific starting point. phsa := 0 ' measurement starts now waitpne(0, |< pin, 0) ' wait for pin to leave low state n := phsa ' grab timer value (may need overhead ' adjustment)Would this work for you?Thanks for the suggestion/idea. I won't be able to try it out until later next week, but I'll let you know how it goes. Thanks again.
Dave
I tried to get your code idea to work, but I think that I'm missing something. It wouldn't return a value. (I'm guessing that I'm missing something obvious.)
The code is:
CON
_clkmode = xtal1 + pll16x ' System clock → 80 MHz
_xinfreq = 5_000_000
CR = 13
pin = 0
OBJ
Debug: "FullDuplexSerialPlus" ' Use with Parallax Serial Terminal to
' display values
PUB null | n
Debug.Start(31, 30, 0, 57600)
waitcnt(clkfreq * 2 + cnt)
Debug.Str(String(13, "going "))
waitcnt(clkfreq*3 + cnt)
Repeat
Debug.Str(String(13, "in program loop "))
n := phsa
Debug.Str(String(13, "n = "))
Debug.Dec(n)
waitcnt(clkfreq/2 + cnt)
I also tried to modify the RC decay example by switching it from POS to NEG detector, and I get a value, but it's always "770" so I have something wrong.
The code is:
CON
CR = 13
OBJ
' display values
PUB Init
'Start serial communication, and wait 2 s for connection to Parallax Serial Terminal.
' Configure counter module.
ctra[30..26] := %01100 ' Set mode to "Neg detector"
ctra[5..0] := 0 ' Set APIN to 0 (P0)
frqa := 1 ' Increment phsa by 1 for each clock tick
main ' Call the Main method
PUB Main | time
repeat
phsa~ ' Clear the phsa register
dira[0]~ ' Pin to input stops charging circuit
Debug.Str(String(13, "in program loop (presse button to stop counter)"))
time := phsa
' Display Result
Debug.Str(String(13, "time = "))
Debug.Dec(time)
Just to repeat my goal. I'd like to be able to start a counter and have it monitor a pin for me, watching for it to go from low to high. I'd like it to then give me a "time" value. It would be like having the program say "go" and then pushing a button to close the circuit. The program would then tell you how long it took you to read the message and push the button. This isn't my finial objective (stated in an earlier post), but the same idea.
Any help would be great. I appreciate everyone's time and suggestions.
Dave
As long as you dont fill in code to initate your action, it will just measure the time between low to high changes on pin.
This is untested and you need to add the CON and OBJ section as in your examples above.
Andy
