Clearing EEPROM
I'm new and I can't figure out how to clear the EEPROM.
I mistakenly pressed F11 and loaded a small program into EEPROM and it worked just fine, but now I want to work on my program.
I've tried powering down, removing the USB cable, reinstalling all, etc. etc. The program just starts up again from the EEPROM.
I know this is a no-brainer but I've spent way too much time and not figured it out.
Kurt Finnie
Kurt Finnie
In other words, just hit F11 again and new code will go into EEPROM.
Searider
John
Upload to EEPROM F11. Upon boot up the Propeller will Do Nothing.
Ron
' using Basic I2C Driver or PASM I2C Driver PRI _errase | i, empty[16] '' errase EEPROM memory longfill(@empty, 0, 16) REPEAT i FROM $0 TO $7FFF STEP 64 write(i, @empty, 64) PUB write (addr, valueAddr, size) | time '' write page to EEPROM with watchdog IF i2c.WritePage(BootPin, EEPROM, addr, valueAddr, size) RETURN false time := cnt repeat while i2c.WriteWait(BootPin, EEPROM, addr) ' wait for watchdog if cnt - time > clkfreq / 10 RETURN false RETURN trueProbably not as efficient as it could be, but it's the way I've do it on a non-time sensitive system.
