Relaunching a spin cog to run pasm. variable preservation. - Page 2 — Parallax Forums
2»
    edited 2011-07-24 23:11
    Yes, specifically bit 7..0 of the instruction/register (which happens to hold the source parameter). For your small fragment it's probably better to use separate register variables. It's not that you need the space.
    Conveniently everything you have in a cog is registers ...
  • marzec309marzec309 Posts: 146
    edited 2011-07-24 23:14
    I must Thank You. You've been a great help and I learned some cool tricks along the way.
    Thanks Again.
    edited 2011-07-25 03:48
    I will leave the lessons and help going as is because it is progressing nicely for you.
    What do you have in the other cogs? Maybe they could be combined simply???
    edited 2011-07-25 19:55
    @Cluso99
    I did have a nice long explanation on what my other cogs were doing. When i went to post it, I was redirected to sign in again, Fail. The page never loaded and I just lost about 30mins of typing. Here is the short version.
    (1) the cog I'm currently working on.
    (2) data input cog, 8 inputs, via shift reg and optoisolators. updates every 3.5uS (PASM)
    (3) Data Output cog, 8 outputs, via shift reg and relays. updates every 0.3mS (SPIN)
    (4) Data logging Cog,w/ serial input(5), SD Card driver(6). receives serial data every 50mS, currently using up ~25mS processing data and writing it to the sd card, waiting/wasting the rest.
    (7) Quadrature Encoder driver, reads data byte from Data input cog(Spin), encoder channels A and B limited to 2.75Khz each(Because of SPIN).
    (8) Data processing, used for some math and standard deviation calculations, responsible for setting alarm conditions and also in charge of a LCD display.
    At least for me there is a lot going on there, once i get the system running as a whole I'll be a little more willing to consolidate cogs.
    I'm currently stuck again though, it appears the Propeller Tool doesn't like a few of my jmp addresses. It States there undefined when they are, I'm sure that there is something I'm missing. Maybe you or Marko, may be willing to lend a hand.
    Here's my current code:
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    ' _xinfreq = 6_250_000
    'Control Constants
      UltraUBufferSize = 20
      maxSD            = 14
      OutputTime       = (80_000_000 / 1000) * 100
    'Output Asignments
      CutDisableMsk      = %1000_0000
      BlowOffMsk         = %0010_0000
      CounterDisableMsk  = %0100_0000
      Alarm1Msk          = %0000_0010
      Alarm2Msk          = %0000_0001
    'Input Asignments
      EnableMsk        = %1000_0000
      CutSigMsk        = %0100_0000
      KnifeProxMsk     = %0010_0000
      CutPosProxMsk    = %0001_0000
      ResetMsk         = %0000_0001
      EncAMsk          = %0000_1000
      EncBMsk          = %0000_0100
      EncCMsk          = %0000_0001
    var
      Long  LengthBuffer
      Long  LogLength
      Long  ErrorBuffer
      Long  StandardDeviation
      Long  CycleTime[2]
      word  BufferPool[UltraUBufferSize]
      byte  BufferCnt
      Byte  UltraUBufferLock
      Byte  I2CLock
      Byte  CogCnt
      Byte  Status
      Byte  RLYOutput
      Byte  DataIn
    obj
      lcd     :       "lcd4Bit"
      Sonic   :       "UltraU_Stream"
      BLOBJ   :       "Buff_Loader_OBJ2"
      DigO    :       "IO_Board_Output_Driver"
      DigI    :       "IO_Board_Input_Driver_PASM"
      Encoder :       "Encoder_Driver"
    dat
    Version        byte    "6.00", 0
    Str0           byte    "                ", 0
    Str1           byte    "        P-CAM   ", 0
    Str2           byte    "  Modual        ", 0
    Str3           byte    "Booting ", 0
    Str4           byte    "Lcd Drv ", 0
    Str5           byte    "SonicDrv", 0
    Str6           byte    " In Drv ", 0
    str7           byte    "Out Drv ", 0
    str8           byte    "Enc Drv ", 0
    str9           Byte    "RUNNING ", 0
    str10          byte    " STOPPED", 0
    str11          byte    "        ", 0
    str12          byte    "UNSTABLE", 0
    str13          byte    "SD calc ", 0
    Pass           Byte    "Success.", 0
    Fail           Byte    "  Fail  ", 0
    Pub main
    'bootup
      UltraUBufferLock := LockNew
      IF lcd.init(8,8,2)
        lcd.blon
        lcd.scrollstr(1, 1, 8, 100, @str1)
        lcd.rscrollstr(1, 2, 8, 100, @str2)
        waitcnt(cnt + clkfreq / 2)
        lcd.moveto(1,2)
        lcd.str(string("Ver#"))
        lcd.str(@Version)
        waitcnt(cnt+clkfreq/2)
        lcd.moveto(1,1)
        lcd.str(@str3)
        lcd.moveto(1,2)
        lcd.str(@Str5)
        waitcnt(cnt + (clkfreq / 1000 * 500))
        IF Sonic.Start(31,30,@BufferPool,@BufferCnt,@LengthBuffer,@LogLength,@ErrorBuffer,@CycleTime,UltraUBufferSize,UltraUBufferLock,EnableMsk,KnifeProxMsk,CutPosProxMsk,@Status,@DataIn)
          lcd.moveto(1,2)
          lcd.str(@Str6)
          if DigI.Start(@DataIn)
            lcd.moveto(1,2)
            lcd.str(@str7)
            if DigO.Start(@RLYOutput)
              lcd.moveto(1,2)
              lcd.str(@str8)
              if Encoder.Start(EncAMsk,EncBMsk,EncCMsk,@LengthBuffer,@ErrorBuffer,@DataIn)
                lcd.moveto(1,2)
                lcd.str(@str13)
                if BLOBJ.Start(@DataIn, @BufferPool,@ErrorBuffer,@RLYOutput,@Status,EnableMsk,ResetMsk,CutDisableMsk,Alarm1Msk,Alarm2Msk,MaxSD,UltraUBufferSize)
                  lcd.moveto(1,2)
                  lcd.str(@Pass)
                  lcd.finalize
                  'sort
                  Coginit(CogID,@sort,@lengthBuffer)
                else
                  lcd.moveto(1,1)
                  lcd.str(@fail)
                  reboot
              else
                lcd.moveto(1,1)
                lcd.str(@fail)
                reboot
            else
              lcd.moveto(1,1)
              lcd.str(@Fail)
              reboot
          else
            lcd.moveto(1,1)
            lcd.str(@Fail)
            reboot
        else
          lcd.moveto(1,1)
          lcd.str(@Fail)
          Reboot
      else
        Reboot
    Dat
                            org     0
    sort                    add     LengthBuffer_, par
                            add     LogLength_, par
                            add     CycleTime_, par
                            add     Status_, par
                            add     RLYOutput_, par
                            add     DataIn_, par
                            mov     BlowOffDisable, #0
                            mov     ErrorSkip, #0
    _one                    mov     frqa, #1
                            movi    ctra, #%0_11111_000          ' LOGIC always
    :loop
    :waitCutSig             rdbyte  tmp, DataIn_
                            test    tmp, #CutSigMsk       wz
                  if_z      jmp     #:waitCutSig
                            mov     phsa,#0
                            rdbyte  tmp, RLYOutput_
                            test    tmp, #CutdisableMsk wz
                  if_z      jmp     #:testAlarm                 'Propeller Tool Doesn't like this address.
                            or      tmp, #CounterDisableMsk
                            wrbyte  tmp, RLYOutput_
                            mov     BlowOffDisable, #2
                            rdbyte  tmp, status_
    _two                    cmp     tmp, #2              wz
                  if_ne     wrbyte  _one, status_
                            mov     ErrorSkip, #1
    :testAlarm              rdbyte  tmp, RLYOutput_
                            test    tmp, #Alarm2Msk    wz
                  if_nz     jmp     #:CheckCutPos
                            or      tmp, #Alarm1Msk
                            wrbyte  _two, status_
                            mov     BlowOffDisable,#3
                            mov     errorSkip, #1
    :CheckCutPos            rdbyte  tmp, datain_
                            test    tmp, #CutPosProxMsk   wz
    :CheckSkip              cmp     errorSkip, #0
                  if_ne     jmp     #:DecrementErrorSkip
                            mov     tmp, phsa
                            wrlong  tmp, cycletime_
                            rdlong  tmp, LengthBuffer_
                            wrlong  par, LengthBuffer_          'zero length buffer
                            wrlong  tmp, LogLength_
    :CheckStopProx          rdbyte  tmp, DataIn_
                            test    tmp, #KnifeProxMsk    wz
                  if_z      jmp     #:CheckStopProx
                            mov     tmp, cycleTime_
                            add     tmp, #4
                            mov     tmp1, phsa
                            wrlong  tmp1, tmp
                            jmp     #:BlowOff
    :DecrementErrorSkip     sub     errorSkip, #1
    :BlowOff                cmp     BlowOffDisable, #0      wz
                  if_ne     jmp     #:DecrementBlowOffDis
                            or      tmp, #BlowOffMsk
                            mov     tmp, outtime
                            add     tmp, cnt
                            waitcnt tmp, #0
                            xor     tmp, #BlowOffMsk
    :DecrementBlowOffDis    sub     BlowOffDisable, #1
                            test    tmp, #CounterdisableMsk   wz
                  if_nz     cmp     BlowoffDisable, #0              wz
                  if_e      xor     tmp, CounterDisableMsk
                  if_e      wrbyte  tmp, RLYOutput_
                            jmp     #:loop                               'Or this address!!!!
    LengthBuffer_ long      0
    LogLength_    long      4
    CycleTime_    long      16
    Status_       long      27
    RLYOutput_    long      28
    DataIn_       long      29
    outtime       long  outputTime
    tmp            res 1
    tmp1           res 1
    BlowOffDisable res 1
    ErrorSkip      res 1
    edited 2011-07-25 20:07
    Problem is that there is a global label in the way (_two). You try to jump to the local label :testAlarm which is behind said global label and therefore not visible. Simply change _two to :two. It's a scope thing.
    edited 2011-07-25 20:18
    @kuroneko
    Man your on your guns. Thanks.
