Relaunching a spin cog to run pasm. variable preservation.
If I relaunch a cog to run PASM what is the best way to preserve the variables setup in Spin? As these are being used by other cogs. My current Object is writen in spin and has proven to be to slow. If I coginit on the current cog would it trash these variables in hub ram?
From my actual knowledge (wich can be improved quite a lot) I always use cognew to be sure the prop-chip itslefs manages completely which cog to use for what
best regards
Stefan
Ya that's how I would have done it. I just mentioned cog 0 because that's is the cog its running on, as its the one the propeller booted on start up(the top most object) and thus were my uncertanty started.
@Phil That would be exactly my situation. At the time this instrucion would exicute all eight cogs are running. The only cog availabe for reperpousing would be the calling cog.
Sorry for any typos or grammer mistakes I'm using my phone don't have access to my laptop at the moment.
pri Sort | BlowOffDisable, errorSkip BlowOffDisable := 0 ErrorSkip := 0 FRQA := $00000001 CTRA := %11111 << 26 repeat repeat until dataIn & CutSigMsk == CutSigMsk PHSA := $00000000 if RLYOutput & CutDisableMsk == CutDisableMsk RLYOutput |= CounterDisableMsk BlowOffDisable := 2 if status <> 2 Status := 1 ErrorSkip := 1 Else repeat if RLYOutput & Alarm2Msk == Alarm2Msk RLYOutput |= Alarm1Msk + CounterDisableMsk BlowOffDisable := 3 status := 2 ErrorSkip := 1 Until dataIn & CutPosProxMsk == CutPosProxMsk if errorSkip == 0 CycleTime[0] := PHSA logLength := LengthBuffer lengthBuffer := 0 repeat until DataIn & KnifeProxMsk == KnifeProxMsk CycleTime[1] := PHSA else ErrorSkip-- if BlowOffDisable == 0 RLYOutput |= BlowOffMsk waitcnt((clkfreq / 1000) * 100 + cnt) RLYOutput ^= BlowOffMsk else BlowOffDisable-- if (RLYOutput & CounterDisableMsk == CounterDisableMsk) and BlowOffDisable == 0 RLYOutput ^= CounterDisableMskThis shouldn't be to difficult to port to pasm. but what is this LMM you are refering too?Ya here is the code:
con _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 ' _xinfreq = 6_250_000 'Control Constants UltraUBufferSize = 20 maxSD = 14 alarmTime = (80_000_000 / 1000) * 42 'Output Asignments CutDisableMsk = %1000_0000 BlowOffMsk = %0010_0000 CounterDisableMsk = %0100_0000 Alarm1Msk = %0000_0010 Alarm2Msk = %0000_0001 'Input Asignments EnableMsk = %1000_0000 CutSigMsk = %0100_0000 KnifeProxMsk = %0010_0000 CutPosProxMsk = %0001_0000 ResetMsk = %0000_0001 EncAMsk = %0000_1000 EncBMsk = %0000_0100 EncCMsk = %0000_0001 var Long LengthBuffer Long LogLength Long ErrorBuffer Long StandardDeviation Long CycleTime[2] word BufferPool[UltraUBufferSize] byte BufferCnt Byte UltraUBufferLock Byte I2CLock Byte CogCnt Byte Status Byte RLYOutput Byte DataIn obj lcd : "lcd4Bit" Sonic : "UltraU_Stream" BLOBJ : "Buff_Loader_OBJ2" DigO : "IO_Board_Output_Driver" DigI : "IO_Board_Input_Driver_PASM" Encoder : "Encoder_Driver" dat Version byte "5.03", 0 Str0 byte " ", 0 Str1 byte " P-CAM ", 0 Str2 byte " Modual ", 0 Str3 byte "Booting ", 0 Str4 byte "Lcd Drv ", 0 Str5 byte "SonicDrv", 0 Str6 byte " In Drv ", 0 str7 byte "Out Drv ", 0 str8 byte "Enc Drv ", 0 str9 Byte "RUNNING ", 0 str10 byte " STOPPED", 0 str11 byte " ", 0 str12 byte "UNSTABLE", 0 str13 byte "SD calc ", 0 Pass Byte "Success.", 0 Fail Byte " Fail ", 0 Pub main | tmp 'bootup UltraUBufferLock := LockNew IF lcd.init(8,8,2) lcd.blon lcd.scrollstr(1, 1, 8, 100, @str1) lcd.rscrollstr(1, 2, 8, 100, @str2) waitcnt(cnt + clkfreq / 2) lcd.moveto(1,2) lcd.str(string("Ver#")) lcd.str(@Version) waitcnt(cnt+clkfreq/2) lcd.moveto(1,1) lcd.str(@str3) lcd.moveto(1,2) lcd.str(@Str5) waitcnt(cnt + (clkfreq / 1000 * 500)) IF Sonic.Start(31,30,@BufferPool,@BufferCnt,@LengthBuffer,@LogLength,@ErrorBuffer,@CycleTime,UltraUBufferSize,UltraUBufferLock,EnableMsk,KnifeProxMsk,CutPosProxMsk,@Status,@DataIn) lcd.moveto(1,2) lcd.str(@Str6) waitcnt(cnt + (clkfreq / 1000 * 500)) if DigI.Start(@DataIn) lcd.moveto(1,2) lcd.str(@str7) waitcnt(cnt + (clkfreq / 1000 * 500)) if DigO.Start(@RLYOutput) lcd.moveto(1,2) lcd.str(@str8) waitcnt(cnt + (clkfreq / 1000 * 500)) if Encoder.Start(EncAMsk,EncBMsk,EncCMsk,@LengthBuffer,@ErrorBuffer,@DataIn) lcd.moveto(1,2) lcd.str(@str13) waitcnt(cnt + (clkfreq / 1000 * 500)) if (tmp := BLOBJ.Start(@DataIn, @BufferPool,@ErrorBuffer,@RLYOutput,@Status,EnableMsk,ResetMsk,CutDisableMsk,Alarm1Msk,Alarm2Msk,MaxSD,UltraUBufferSize)) lcd.moveto(1,2) lcd.str(@Pass) lcd.finalize Sort else lcd.moveto(1,1) lcd.str(@fail) reboot else lcd.moveto(1,1) lcd.str(@fail) reboot else lcd.moveto(1,1) lcd.str(@Fail) reboot else lcd.moveto(1,1) lcd.str(@Fail) reboot else lcd.moveto(1,1) lcd.str(@Fail) Reboot else Reboot pri Sort | BlowOffDisable, errorSkip BlowOffDisable := 0 ErrorSkip := 0 FRQA := $00000001 CTRA := %11111 << 26 repeat repeat until dataIn & CutSigMsk == CutSigMsk PHSA := $00000000 if RLYOutput & CutDisableMsk == CutDisableMsk RLYOutput |= CounterDisableMsk BlowOffDisable := 2 if status <> 2 Status := 1 ErrorSkip := 1 Else repeat if RLYOutput & Alarm2Msk == Alarm2Msk RLYOutput |= Alarm1Msk + CounterDisableMsk BlowOffDisable := 3 status := 2 ErrorSkip := 1 Until dataIn & CutPosProxMsk == CutPosProxMsk if errorSkip == 0 CycleTime[0] := PHSA logLength := LengthBuffer lengthBuffer := 0 repeat until DataIn & KnifeProxMsk == KnifeProxMsk CycleTime[1] := PHSA else ErrorSkip-- if BlowOffDisable == 0 RLYOutput |= BlowOffMsk waitcnt((clkfreq / 1000) * 100 + cnt) RLYOutput ^= BlowOffMsk else BlowOffDisable-- if (RLYOutput & CounterDisableMsk == CounterDisableMsk) and BlowOffDisable == 0 RLYOutput ^= CounterDisableMskI'm porting the PRI Sort to PASM to be relaunched into the same cog. I know how the get the address of the global variables into PASM, Can I Pass the address of the constants to the PASM routine or even use those constants in PASM and have the compiler do it for me?This is how I'm trying to get the variables into PASM:
Dat org 0 sort mov tmp, par mov LengthBufferAddr, tmp add tmp, #4 mov LogLengthAddr,tmp add tmp, #12 mov Cycle1TimeAddr, tmp add tmp, #4 mov Cycle2TimeAddr, tmp add tmp, #7 mov StatusAddr, tmp LengthBufferAddr res 1 LengthHolderAddr res 1 Cycle1TimeAddr res 1 Cycle2TimeAddr res 1 StatusAddr res 1 tmp res 1Was not sure how to get the predefined constants into PASM.
The only issue I see with the sort method is the waitcnt target which may have to go into a constant pool in your cog image.
OK, I tried to use the variables as they are, it will not compile. Could you tell me what I've done wrong? can i use "test" with two variables?
Dat org 0 sort mov BlowOffDisable, #0 mov ErrorSkip, #0 mov frqa, #1 movi ctra, #%0_11111_000 ' LOGIC always :loop :waitCutSig test DataIn, #CutSigMsk wz if_z jmp #:waitCutSig mov phsa,#0 test RLYOutput, #CutdisableMsk wz if_z jmp #:testAlarm or RLYOutput, #CounterDisableMsk mov BlowOffDisable, #2 cmp Status, #2 wz if_ne mov status, #1 mov ErrorSkip, #1 :testAlarm test RLYOutput, #Alarm2Msk wz if_nz jmp #:CheckCutPos or RLYOutput, #Alarm1Msk or RLYOutput, #CounterDisableMsk mov BlowOffDisable,#3 mov status, #2 mov errorSkip, #1 :CheckCutPos test dataIn, #CutPosProxMsk wz if_z jmp #testAlarm :CheckSkip cmp errorSkip, #0 if_ne jmp #:DecrementErrorSkip mov CycleTime[0], phsa mov LogLength, LengthBuffer mov lengthBuffer, #0 :CheckStopProx test DataIn, #KnifeProxMsk wz if_z jmp #:CheckStopProx mov CycleTime[1], phsa :DecrementErrorSkip sub errorSkip, #1 cmp BlowOffDisable, #0 wz if_ne jmp #:DecrementBlowOffDis or RLYOutput, #BlowOffMsk mov tmp, outtime add tmp, cnt waitcnt tmp, #0 xor RLYOutput, #BlowOffMsk :DecrementBlowOffDis sub BlowOffDisable, #1 test RLYoutput, #CounterdisableMsk wz if_nz cmp BlowoffDisable, #0 wz if_e xor RLYOutput, CounterDisableMsk jmp #:loop outtime long outputTime tmp res 1 BlowOffDisable res 1 ErrorSkip res 1I am presuming you do not have a spare cog??? If you do, then what you are trying to do would be relatively easy in another cog running pasm, without the need to relaunch it.
No, I don't have a spare cog and thus why I'm having difficulties. the use of LMM is very interesting.
Thanks I'll try reading them into a temp variable first. I didn't think mov CycleTime[n], phsa was valid ether, I just figured i would cross that bridge when I got to it.
VAR [COLOR="red"]long eins[/COLOR] long zwei long drei[3] long vier PUB null coginit(cogid, @entry, @eins) DAT org 0 entry add eins_, par ' resolve addresses from offsets add zwei_, par ' add drei_, par ' add vier_, par ' rdlong temp, eins_ ' access to [color=red]long eins[/color] ' ... eins_ long 0 ' holds VAR hub addresses zwei_ long 4 ' these values are preset with their drei_ long 8 {3 longs} ' corresponding offsets vier_ long 20 ' fitThat is OK, What I wrote isn't useless, I just have to set up my variables and append my code a little. I should be able to make it work. Even having to read the variables from the hub ram, it should be a lot faster than its SPIN equivalent.
con _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 ' _xinfreq = 6_250_000 'Control Constants UltraUBufferSize = 20 maxSD = 14 OutputTime = (80_000_000 / 1000) * 100 'Output Asignments CutDisableMsk = %1000_0000 BlowOffMsk = %0010_0000 CounterDisableMsk = %0100_0000 Alarm1Msk = %0000_0010 Alarm2Msk = %0000_0001 'Input Asignments EnableMsk = %1000_0000 CutSigMsk = %0100_0000 KnifeProxMsk = %0010_0000 CutPosProxMsk = %0001_0000 ResetMsk = %0000_0001 EncAMsk = %0000_1000 EncBMsk = %0000_0100 EncCMsk = %0000_0001 var Long LengthBuffer Long LogLength Long ErrorBuffer Long StandardDeviation Long CycleTime[2] word BufferPool[UltraUBufferSize] byte BufferCnt Byte UltraUBufferLock Byte I2CLock Byte CogCnt Byte Status Byte RLYOutput Byte DataIn obj lcd : "lcd4Bit" Sonic : "UltraU_Stream" BLOBJ : "Buff_Loader_OBJ2" DigO : "IO_Board_Output_Driver" DigI : "IO_Board_Input_Driver_PASM" Encoder : "Encoder_Driver" dat Version byte "6.00", 0 Str0 byte " ", 0 Str1 byte " P-CAM ", 0 Str2 byte " Modual ", 0 Str3 byte "Booting ", 0 Str4 byte "Lcd Drv ", 0 Str5 byte "SonicDrv", 0 Str6 byte " In Drv ", 0 str7 byte "Out Drv ", 0 str8 byte "Enc Drv ", 0 str9 Byte "RUNNING ", 0 str10 byte " STOPPED", 0 str11 byte " ", 0 str12 byte "UNSTABLE", 0 str13 byte "SD calc ", 0 Pass Byte "Success.", 0 Fail Byte " Fail ", 0 Pub main 'bootup UltraUBufferLock := LockNew IF lcd.init(8,8,2) lcd.blon lcd.scrollstr(1, 1, 8, 100, @str1) lcd.rscrollstr(1, 2, 8, 100, @str2) waitcnt(cnt + clkfreq / 2) lcd.moveto(1,2) lcd.str(string("Ver#")) lcd.str(@Version) waitcnt(cnt+clkfreq/2) lcd.moveto(1,1) lcd.str(@str3) lcd.moveto(1,2) lcd.str(@Str5) waitcnt(cnt + (clkfreq / 1000 * 500)) IF Sonic.Start(31,30,@BufferPool,@BufferCnt,@LengthBuffer,@LogLength,@ErrorBuffer,@CycleTime,UltraUBufferSize,UltraUBufferLock,EnableMsk,KnifeProxMsk,CutPosProxMsk,@Status,@DataIn) lcd.moveto(1,2) lcd.str(@Str6) waitcnt(cnt + (clkfreq / 1000 * 500)) if DigI.Start(@DataIn) lcd.moveto(1,2) lcd.str(@str7) waitcnt(cnt + (clkfreq / 1000 * 500)) if DigO.Start(@RLYOutput) lcd.moveto(1,2) lcd.str(@str8) waitcnt(cnt + (clkfreq / 1000 * 500)) if Encoder.Start(EncAMsk,EncBMsk,EncCMsk,@LengthBuffer,@ErrorBuffer,@DataIn) lcd.moveto(1,2) lcd.str(@str13) waitcnt(cnt + (clkfreq / 1000 * 500)) if BLOBJ.Start(@DataIn, @BufferPool,@ErrorBuffer,@RLYOutput,@Status,EnableMsk,ResetMsk,CutDisableMsk,Alarm1Msk,Alarm2Msk,MaxSD,UltraUBufferSize) lcd.moveto(1,2) lcd.str(@Pass) lcd.finalize 'sort Coginit(CogID,@sort,@lengthBuffer) else lcd.moveto(1,1) lcd.str(@fail) reboot else lcd.moveto(1,1) lcd.str(@fail) reboot else lcd.moveto(1,1) lcd.str(@Fail) reboot else lcd.moveto(1,1) lcd.str(@Fail) reboot else lcd.moveto(1,1) lcd.str(@Fail) Reboot else Reboot Dat org 0 sort add LengthBuffer_, par add LogLength_, par add CycleTime_, par add Status_, par add RLYOutput_, par add DataIn_, par mov BlowOffDisable, #0 mov ErrorSkip, #0 mov frqa, #1 movi ctra, #%0_11111_000 ' LOGIC always :loop :waitCutSig rdbyte tmp, DataIn_ test tmp, #CutSigMsk wz if_z jmp #:waitCutSig mov phsa,#0 rdbyte tmp, RLYOutput_ test tmp, #CutdisableMsk wz if_z jmp #:testAlarm rdbyte tmp, RLYOutput_ or tmp, #CounterDisableMsk wrbyte tmp, RLYOutput_ mov BlowOffDisable, #2 rdbyte tmp, status_ cmp tmp, #2 wz if_ne wrbyte 1, status_ mov ErrorSkip, #1 :testAlarm rdbyte tmp, RLYOutput_ test tmp, #Alarm2Msk wz if_nz jmp #:CheckCutPos rdbyte tmp, RLYOutput_ or tmp, #Alarm1Msk or tmp, #CounterDisableMsk wrbyte tmp, RLYOutput_ wrbyte 2, status_ mov BlowOffDisable,#3 mov errorSkip, #1 :CheckCutPos rdbyte tmp, datain_ test tmp, #CutPosProxMsk wz if_z jmp #:testAlarm :CheckSkip cmp errorSkip, #0 if_ne jmp #:DecrementErrorSkip wrlong phsa, cycletime_ rdlong tmp, LengthBuffer_ wrlong tmp, LogLength_ wrlong 0, LengthBuffer_ :CheckStopProx rdbyte tmp, DataIn_ test tmp, #KnifeProxMsk wz if_z jmp #:CheckStopProx mov tmp, cycleTime_ add tmp, #4 wrlong phsa, tmp jmp #:BlowOff :DecrementErrorSkip sub errorSkip, #1 :BlowOff cmp BlowOffDisable, #0 wz if_ne jmp #:DecrementBlowOffDis rdbyte tmp, RLYOutput_ or tmp, #BlowOffMsk wrbyte tmp, RLYOutput_ mov tmp, outtime add tmp, cnt waitcnt tmp, #0 rdbyte tmp, RLYOutput_ xor tmp, #BlowOffMsk wrbyte tmp, RLYOutput_ :DecrementBlowOffDis sub BlowOffDisable, #1 rdbyte tmp, RLYOutput_ test tmp, #CounterdisableMsk wz if_nz cmp BlowoffDisable, #0 wz if_e xor tmp, CounterDisableMsk if_e wrbyte tmp, RLYOutput_ jmp #:loop '***************************************************************** LengthBuffer_ long 0 LogLength_ long 4 CycleTime_ long 16 Status_ long 27 RLYOutput_ long 28 DataIn_ long 29 outtime long outputTime tmp res 1 BlowOffDisable res 1 ErrorSkip res 1if_ne wrbyte 1, status_ wrbyte 2, status_ wrlong phsa, cycletime_ wrlong 0, LengthBuffer_ wrlong phsa, tmpPutting 0..2 into the destination slot doesn't do what you think it does. It's effectively addressing registers 0..2. Also, phsa - if used in the destination slot - only writes the shadow register, not the counter. So at least do: As for writing zero use wrlong par, LengthBuffer_ (par's shadow is usually empty), 1 and 2 should use register references or you could hi-jack some of the code, e.g._one mov frqa, #1 ... if_ne wrbyte _one, status_and_two cmp tmp, #2 wz ... wrbyte _two, status_was trying to write a decimal 1 to address @status along with dec 2 later on.
I understand what you said about: But i don't understand this at all
_one mov frqa, #1 if_ne wrbyte _one, status_ _two cmp tmp, #2 wz wrbyte _two, status_That said, you can't do wrlong #1, addr. It has to be along the lines of
wrbyte _one, addr ... _one long 1 _two long 2So instead of defining two new register constants (for 1 and 2) the code below uses existing instructions where it knows that the lower byte (source for wrbyte) has the appropriate value._one mov frqa, [COLOR="red"]#1[/COLOR] ... if_ne wrbyte _one, status_ _two cmp tmp, [COLOR="red"]#2[/COLOR] wz ... wrbyte _two, status_I probably get -10 points for doing (or even suggesting) it but I think it's useful.
