BMA Multi-COG PASM Debugger V1.91 Now Available — Parallax Forums
jazzedjazzed Posts: 11,803
edited 2012-05-01 21:02 in Propeller 1
Here is a simple on chip PASM debugger. The BMAdebugger does not use a GUI.
Debugging is most effective when used in conjunction with BSTC compiler .list files.
  • Small and simple on chip PASM debugger
  • No Windows or other PC program required
  • Feature rich command set
  • Multi-COG debug ability
You do not need previous versions. The latest version is the one to download/use.
BMADebugger Version 1.91:
Compiles with Propeller Tool
Can still be used with SPINSIM with minor edits.
BMADebugger Version 1.9: new features
 * fixed: bug where jmp instruction would not clear wz.
 * fixed: bug where djnz was post decrementing. djnz pre-decrements.
 * changed: made multicore example more interesting.
 * changed: default baudrate to 115200.
 * changed: rx method so either $a or $d indicates end of line.
BMADebugger Version 1.8: new features
 * added: animate command
 * changed: go command so it prints breakpoints if hit within a second.
 * changed: iterate command so it prints correct D values.
 * changed: default xinfreq 5_000_000
BMADebugger Version 1.7: new features
 * added: support for multi-cog debugging.
 * added: task command "tx" which sets the COG task to debug.
 * updated: demo program to show how multi-cog debugging is started.
Example
con
  _CLKMODE      = XTAL1 + PLL16x
  _XINFREQ      = 6_000_000
obj
  bu    : "BMAutility"          ' BMA debugger utility routines
  s     : "FullDuplexSingleton" ' required for single stepping with main/stepDump
pub main | n
This is the main debugger entry point.
  waitcnt(clkfreq*1+cnt)        ' wait a second for user to start terminal
  s.start(31,30,0,115200)       ' start the default serial interface
  readptr := @readbuf
' bu.debug(@entry,@command)     ' start single cog task debugger utility
  bu.taskstart(@entry, @command, string("Main Task"))
  bu.taskstart(@entry2,@command, 0)
  bu.start                      ' start multi cog task debugger
  repeat
dat
' stepper and test code ... the entry point for your PASM
entry          org      0       ' THE ENTRY ORG LABEL
long 0 [noparse][[/noparse]8]    ' debugger stub space ... if no debugger, these are nops
' your PASM goes here.
dat
' stepper and test code for second cog "task"
entry2         org      0       ' THE ENTRY ORG LABEL
BMADebugger Version 1.6: new features
 * added: next command "n" which steps over call/jmpret subroutine bodies.
 * added: iterate x command "ix" which steps through instructions showing execution at PC = x.
 * changed: list command "l" without arguments prints PC + 16 lines or prints from last list end PC + 16.
BMADebugger Version 1.5: list and special registers update
  * changed: no longer necessary to start debugger before starting utility
  * fixed: special register values now print correctly in stepper list output
Version 1.4: Bugfix for DJNZ and NOP instruction detect.
  * Essentially, this is the same as version 1.3
  * added: Example of tight HUB buffer write with djnz.
Version 1.3: Some fixes and enhancements.
  * added: StefanL38's list/step explanation to BMAdebugger_Demo.spin
  * added: Expanded command user guide to BMAdebugger_Demo.spin
  * added: "R" command that allows restarting a COG
  * added: "f" command for filling HUB data with various type width values
  * added: "h" command for dumping HUB data with various type widths
  * added: "?" for only syntax/command help summary
  * changed: Special register addresses $1f0-$1ff in listings now show as mnemonics
  * changed: "p" commands now show the COG special registers (not shadow)
  * changed: "s" command lets you change the COG special registers (not shadow)
  * changed: Method for calling the debug utility has changed
  * fixed: "c" command was totally broken; works now
Version 1.2: Added real-time run to breakpoint
  * changed: debugger stub needs 8 words now for realtime run to breakpoint.
  * changed: "L x n" to "l x n" and "l" to "L" ... upper case lists all
  * changed: "D x n" to "d x n" and "d" to "D" ... upper case dumps all
  * added: "PC xcogadr Ok> " so it's easier know where we are during debug
  * changed: Method for including the debug stub has changed.
Version 1.1: Added debug features
  * added breakpoint toggle and clear.
     - "b x" toggles breakpoint at address x.
     - "c" clears all breakpoints.
  * added "D x n" to allow cog dump of n longs from register x.
  * added "l" print disassembly list for entire COG.
  * added "L x n" to allow disassembly list n instructions from address x.
  * added "s x n" to allow setting register at address x with value n.
  * added code so that "z" prints Z and C states.
  * debug step now shows full and correct resultant state of destination register.
  * debug result destination register is delimited by "D=".
  * added current instruction word to step list temporarily for confidence.
«13
    edited 2009-08-08 19:04
    So in 4 hours you have written two whole revisions !!
    Go on then, what was so terriable with V0.3 that you deemed that it should never see the light od day ???
    Style and grace : Nil point
  • jazzedjazzed Posts: 11,803
    edited 2009-08-08 20:33
    Funny [noparse]:)[/noparse] V0.3 was intermediate. V1.x will be a release to obex after enough testing.
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
    Post Edited (jazzed) : 8/23/2009 6:53:19 PM GMT
    edited 2009-08-08 22:25
    Versions that get skipped over always hold a mystery, to me. hopefully tommorow I shall be given a chance to try Bmad out.
    If only that grass would stop growing, or the beer can powered mover would fire up.
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-08-23 18:56
    jazzed·said...
    BMAD is an acronym for "Be My Asm Debugger"
    Oh bummer, Steve,·I was really hoping you'd call it the SPUD Gun ...
    > in the spirit of Mr. Rogers
    " Can you say no bugs ?"
    LOL - I'm sure I've posted here before about one of the (huge) programs we had to maintain from a long-departed coder. The guy happened to be enamoured with Mr.Rogers. So he named all of his routines after something in the 'neighborhood'.·· Mr. Rogers still haunts my nightmares. freaked.giflol.gif· Let's see...oh the 'trolley' function is the dispatch table lookup. <G>
    Seriously... thanks for your efforts ... I'll try it out as soon as I get a breather!
    - H
    edited 2009-08-23 19:00
    Hi. I've posted version 1.0 of the BMA debugger above. This revision dramatically reduces the debugger stub COG footprint.
    Please download V1.0, try it out, and provide feedback. Bugs will be fixed when identified. Feature requests will be considered.
    Howard, this is a different program. SPUD will integrate spin and cog selectable pasm debugging into one package.
    If you look hard enough, you can find the real meaning of BMA in the source wink.gif Mr. Rogers was just a nice reference.
    --Steve
    Propeller Tools Post Edited (jazzed) : 8/27/2009 3:32:41 AM GMT
  • mikedivmikediv Posts: 825
    edited 2009-08-25 20:07
    Hey Jazzed thanks for sharing your stuff with us, I always look forward to your posts
    edited 2009-08-26 02:38
    Thanks mikediv [noparse]:)[/noparse]
    I've enhanced the features of the BMA debugger. They are described above and are in the V1_1 .zip package.
    --Steve
    Propeller Tools Post Edited (jazzed) : 8/27/2009 3:32:59 AM GMT
    edited 2009-08-28 03:23
    · Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
    edited 2009-09-11 18:09
    Hi. BMA debugger 1.2 is now available. It will now run to breakpoint in real time.
    Also, I will create a Java Application (cross platform) GUI version of this later to make debugging easier.
    Note that you the way the stub is added has changed. Now you only need to add long 0 [noparse][[/noparse]8] to the top of code for debug. No more copy paste the stub, the debugger will do that for you.
    --Steve
    Propeller Tools
  • Agent420Agent420 Posts: 439
    edited 2009-09-11 18:47
    I'm going to try a 'Debugger Tour' this weekend and will certainly give this a look.· Thanks in advance for your work on the project!
    edited 2009-09-12 19:24
    Hello Steve,
    I have done some PASM-programs a some months ago.
    and I have some experience in 6502 ASM a long time ago.
    If I start your Democode I can single-step through the code.
    I'm almost completely stumped by the output
    I'm sure by taking 2-3 days 12 hours a day time I can figure out what all the debug-output means.
    But I would like to ask if you can post an explanation of it all
    concrete questions
     xor     6CFFE801     D:1F4 00000000 S#001          D=1F4 00000001
    1.) what is the meaning of "6CFFE801" ?
    2.) what is the meaning of "D:" ?
    3.) what is the meaning of "1F4" ? (COG-RAM adress ??
    4.) what is the meaning of "00000000 " (part of the long value containing the xor-value which bits ?)
    5.) what is the meaning of "S#001" ? (# immediate value ?, 001 the value itself ? what is the "S" for ?
    6.) what is the meaning of "D=1F4" ? another COG-RAM adress ? which one ?
    7.) what is the meaning of "00000001" ? (again the value "#1" from the sourcecode ?
    as you can see from these many questions I understand almost nothing.
    I would find it very ineffective to check all my assumings by a lot of try and error-experiments
    with variing the democode
    So I would really appreciate if somebody could answer my questions
    best regards
    Stefan
    edited 2009-09-12 19:52
    Hi Stefan.
    Thanks for taking time to try this out. I'll answer questions in line and add the Q&A in some form to the demo source.
      1.) what is the meaning of "6CFFE801" ? A. "6CFFE801" is the instruction for "xor $1f4, #1" ... otherwise known as "xor OUTA, #1" 2.) what is the meaning of "D:" ? A. "D:" is the destination field of the before the instruction executes. 3.) what is the meaning of "1F4" ? (COG-RAM adress ?? A. Yes, it is the address of OUTA ... note to self, use mnemonics where possible. 4.) what is the meaning of "00000000 " (part of the long value containing the xor-value which bits ?) A. "00000000 " is the value of D:address before the instruction executes. 5.) what is the meaning of "S#001" ? (# immediate value ?, 001 the value itself ? what is the "S" for ? A. "S#001" is the immediate value the instruction will use when it executes. "S 001" would be the source address for the instruction to use. 6.) what is the meaning of "D=1F4" ? another COG-RAM adress ? which one ? A. "D=1F4" is the destination address after the instruction executes otherwise known as OUTA. 7.) what is the meaning of "00000001" ? (again the value "#1" from the sourcecode ? A. "00000001" is the result in the D register after the instruction executes. > as you can see from these many questions I understand almost nothing. Actually, from your questions, you appear to have guessed quite a bit.
    Cheers
    Edit: 1F4 is OUTA not DIRA
    --Steve
    Propeller Tools Post Edited (jazzed) : 9/12/2009 8:13:25 PM GMT
    edited 2009-09-12 20:41
    Helle Steve,
    thank you very much for the explanation
    I would like to make a suggestion how to comment this in the file
    explanations
       (1)(2)       (3)        (4)         (5)   (6)      (7)   (8)      (9)    (10) (11)
    PC 00A Z      : mov     A0E85011     D:028 00000000 S#011          D=028 00000000 C
    PC 013 .      : mov     A0BC5028     D:028 04C4B400 S:028 04C4B400 D=028 04C4B400 Z
    original line of code in the propeller-tool
      if_z mov     t0,      #$11
           mov     t0,      t0
     (1) program-counter
     (2) flag-condition                                             (at PC 00A "if_z"  at PC 013 ".")
     (3) mnemonic of the PASM-command                               (at PC 00A "mov"   at PC 013 "mov")
     (4) 32-bitvalue of long at PC                                  (at PC 00A "A0E85011")
     (5) Destination-adress of command BEFORE executing the command (at PC 00A "028")
     (6) Value of destination BEFORE executing the command          (at PC 013 "04C4B400")
     (7) Source_adress of the command                               (at PC 00A "S#011" at PC 013 "028") [noparse][[/noparse]S#011] means immediate value NO dest-adress
     (8) Value of Source                                            (at PC 013 "04C4B400"
     (9) Destination-adress of command AFTER executing the command  (at PC 013 "028")
    (10) Value of destination AFTER command has executed            (at PC 00A no value as it is immediate at PC 013 "04C4B400")
    (11) status of C and Z-flag (if mentioned flag is SET           (at PC 00A "C" carry-flag is set at PC 013 Z-flag is set)
    did I explain that right ?
    your demo is written from a POV of functionality of the code (blink LEDs)
    to explain the debug-output I think it would be very useful
    to have some lines of code that show changes in EVERY columm that can easily be calculated in anyones head
    have three "variables" like "t0"
    load them with values $10, $05, $03
    and code something with command "add" and "sub" where source and destination have different but easy to find values
    a second example could show self modifying code
    an explanation like this would drop down the hurdle for learning PASM to 1 feet (as anybody can easily step over it)
    best regards
    Stefan
    edited 2009-09-12 21:34
    StefanL38 said...
    did I explain that right ? ...
    Indeed !
    You have explained it very nicely. If you don't mind I'll include a version of this in the next release.
    I'll come up with more examples to include in the package. If you have something else to contribute, I'll add it too.
    --Steve
    Propeller Tools
    edited 2009-09-13 01:59
    Hi Steve,
    Very Nice indeed. When I did my debugger, I only re-displayed the destination if it was changed. Makes it easier to see where something is changed.
    · Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
    edited 2009-09-13 19:06
    Hello, I've posted version 1.3 with code/documentation enhancements.
    Previously the "pr" command would only print the special register shadow values. This has been corrected ... now you can see the COG value of DIRA/OUTA for example; you can still look at the shadow values with the dump and list commands. I added a COG restart command for times when the go command causes the debugger to lose control. This allows user to reload the debug session without having to re-download the code. The clear breakpoint command was horribly broken [noparse]:)[/noparse] Other details have changed: see the top post. I've tested all commands before posting V1.3 to make sure they behave the way are described in the expanded user guide.
    Ray (@Cluso99), I think each of us has preferences. I found only printing changes to be somewhat annoying because I didn't have a "step-record" of the changes to look at during debug. Of course a GUI would not have a step-record either unless the underlying "debug server" contents are captured in an optional console window.
    There are many wonderful things that can be done and options that can be satisfied with a GUI that an on-chip debugger can not do. This is why I'm ultimately committed to writing a GUI client ... just not today [noparse]:)[/noparse]
    Cheers.
    --Steve
    Propeller Tools
    edited 2009-09-19 17:29
    BMAdebugger Version 1.4 with some bug fixes and more example code is now available.
    --Steve
    Propeller Tools
  • dMajodMajo Posts: 862
    edited 2009-09-21 10:41
    Nice, Steve!
    I will give it a try when I receive back my hardware
    · Propeller Object Exchange (last Publications / Updates)
    edited 2009-12-21 19:38
    BMA Debugger V1.5 was downloaded 23 times.
    BMA Debugger V1.6 is now available. New commands:
      n : steps over call/jmpret subroutine bodies. ix : steps through instructions until keyboard hit showing execution at PC = x.
    See the demo file for full command help. BMA is run completely on the Propeller - a GUI is not provided or planned.
    The tool is most effective when used in conjunction with the BSTC compiler/list output.
    edited 2009-12-23 05:54
    BMA Debugger is now multi-cog. More than one cog can be started in the debugger.
    The task command lets you switch between cog debug sessions.
    The cogs can be run in real-time and stop at break-points or be stepped.
    Only the active debug task can be stepped or dumped.
    Tasks can be named at startup for user convenience.
    The old single-cog debug still works as task 0 if started the old way.
    Here is a sample console session with two cogs.
    Starting BMA Debugger task 0 Main Task
    Starting BMA Debugger task 1
    BMA Debugger Task 0
    T0.PC 008 Ok>
    T0.PC 008 .      : jmp     5C7C000F   N D:000  083C01F3 S#00F           D=000  083C01F3
    T0.PC 00F .      : or      68FFEC83     D:DIRA 00000000 S#083
    T0.PC 00F Ok>
    T0.PC 00F .      : or      68FFEC83     D:DIRA 00000000 S#083           D=DIRA 00000083
    T0.PC 010 .      : mov     A0BC1BF0     D:00D  00000000 S:PAR  0000234C
    T0.PC 010 Ok>
    T0.PC 010 .      : mov     A0BC1BF0     D:00D  00000000 S:PAR  0000234C D=00D  0000234C
    T0.PC 011 .      : mov     A0BC1DF0     D:00E  00000000 S:PAR  0000234C
    T0.PC 011 Ok>
    T0.PC 011 .      : mov     A0BC1DF0     D:00E  00000000 S:PAR  0000234C D=00E  0000234C
    T0.PC 012 .      : add     80FC1C04     D:00E  0000234C S#004
    T0.PC 012 Ok>
    t 1
    T1.PC 008 Ok>
    T1.PC 008 nop    : nop     00000000   N D:000  083C01F3 S:000  083C01F3 D=000  083C01F3
    T1.PC 009 nop    : nop     00000000   N D:000  083C01F3 S:000  083C01F3
    T1.PC 009 Ok>
    T1.PC 009 nop    : nop     00000000   N D:000  083C01F3 S:000  083C01F3 D=000  083C01F3
    T1.PC 00A nop    : nop     00000000   N D:000  083C01F3 S:000  083C01F3
    T1.PC 00A Ok>
    T1.PC 00A nop    : nop     00000000   N D:000  083C01F3 S:000  083C01F3 D=000  083C01F3
    T1.PC 00B nop    : nop     00000000   N D:000  083C01F3 S:000  083C01F3
    T1.PC 00B Ok>
    T1.PC 00B nop    : nop     00000000   N D:000  083C01F3 S:000  083C01F3 D=000  083C01F3
    T1.PC 00C nop    : nop     00000000   N D:000  083C01F3 S:000  083C01F3
    T1.PC 00C Ok>
    t 0
    Task : Main Task
    T0.PC 012 Ok>
  • BradCBradC Posts: 2,601
    edited 2009-12-23 06:00
    jazzed said...
    Oh, that is dead sexxxxxxxxxxxxxxxxxxxy. Well done indeed!
    Life may be "too short", but it's the longest thing we ever do.
    edited 2010-07-16 16:50
    Hello,
    The BMAD PASM Multi-COG debugger is updated to version 1.8 in the first post.
    Added animation, fixed some bugs.
    Cheers,
    --Steve
    Propeller Pages: Propeller JVM
    edited 2011-02-11 17:22
    Updated to version 1.9 with some bug fixes.
    edited 2011-07-24 06:53
    BMA/PASD Comparisons
    BMA                                     PASD
    Step animation record                   No step animation record
    Multi-COG debugger                      Single COG debugger only
    [COLOR="red"]Can use any complier[/COLOR]                    Must use Propeller Tool
    Command line tool + terminal program    Windows program
    Needs long 0 [8] at addr 0 for stub     User adds 12 instructions at addr 0
    Requires using listings for symbols     Has symbol address/data in windows
    How should I interpret this statement? The current 1.9 requires bst[c] for compilation (BMAUtility uses #ifndef & Co).
    edited 2011-07-24 06:56
    I'll provide an update.
    edited 2011-07-24 07:05
    kuroneko wrote: »
    BMA                                     PASD
    Fixed in version 1.91. Propeller Tool is also limiting :)
    edited 2011-07-24 07:55
    Hi Steve,
    than you very much for the comparison table.
    best regards
    Stefan
  • RS_JimRS_Jim Posts: 1,777
    edited 2011-09-11 06:52
    Steve,
    I have an object written in PASM that when i debug with PSAD seems to be working fine, however when I connect it to the driving spin program, It crashes and burns! Wil BMA allow me to see what is happening in my object when I start it and pass the variables to it from the top spin file?
    Jim
    edited 2011-09-11 08:55
    RS_Jim wrote: »
    Steve,
    Jim
    Jim,
    The approach I take is to breakup the SPIN program into 3 pieces in the first PUB function.
    1. start the serial object
    2. cognew the rest of the program that will use the PASM
    3. start the debugger
    Here is a simple example of splitting up a program.
    CON
      _CLKFREQ      = 80_000_000
    OBJ
      d : "BMAUtility"
    PUB main
      ' 1. start the serial object
      waitcnt(clkfreq+cnt)          ' wait a second for user to start terminal
      ' 2. cognew the rest of the program that will use the PASM
      cognew(myprogram, @stack)
      ' 3. start the debugger
      d.debug(@entry,@command)
      ' if we don't want the debugger to run replace steps 2 and 3 with this
      cognew(@entry,@command)
      myprogram
    VAR
      long stack[100]  ' stack space for myprogram
    PUB myprogram
      ' main program loop goes here
      repeat
        command := 1
        repeat while command
    VAR
      long command
      long data
    DAT
    ' test code
    long 0 [8]     ' debugger stub space ... if no debugger, these are nops
    ' main cog program loop
    CmdDone
        ' let the user program know the command is done
                  wrlong zero, par
    CmdLoop
        ' wait for a command
                  rdlong cmd, par
                  tjz cmd, #CmdLoop
        ' process command
        ' PASM takes action on command request then jumps back to main loop
                  jmp #CmdDone
    zero    long 0
    cmd     res 1
    BTW: PST has no way to control input echo to the console, so you will see command input echoed there. It is better to use a program that doesn't echo. I've attached the "uterm" .net program that works nicely in a "cmd" window.
    I use uterm with BSTC which provides a very nice listing to help with debugging.
    BST can be used for all of this debugging stuff too.
    edited 2011-09-11 17:04
    jazzed wrote: »
    Is this about the Echo On tickbox in PST? Works for me.
