Ground Planes and Proto Board
Hello Everyone
I may be destroying a perfectly patentable idea here, but I would like other peoples input.
Anyhow, let's say that a person is using one of those beautiful, awesome, and lovely Parallax Propeller Proto Boards, and let's say this person wants to add an IC to the Proto Board that requires a substantial ground plane under the IC, such as a stepper driver IC.
Is this feasible or does this already exist:
Copper sheeting with pins spaced 0.10" apart that can be cut to form a ground plane that can be soldered to a prototype board?
Bruce
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=33115CA-ND
Well that was pretty cool! I went to their home page and they have some pretty interesting stuff. Definitely worth a visit and marking as a favorite.
http://www.capitaladvanced.com/index.html
Bruce
Bruce
Cut copper sheeting to the desired shaped. Drill (4) 0.026 diameter holes 0.10" on center, and tack in place with 22 gauge wire and attach to ground.
Bruce
EDIT: Route all (4) 22 gauge wires back to ground. It is just a suggestion.
What the heck does that mean?
Bruce
Bruce
http://www.dartmouth.edu/~sullivan/prototyping.pdf
Thanks for the document link. It is always nice to see the techniques of others.
If I'm understanding you correctly, some 3M adhesive copper foil strip tape might do the trick.
-Mark
That also sounds pretty good. Just entend it out from under the IC and tack it to ground. Never seen that product from 3M though. What is it normally used for?
Bruce
Jim
There is another thing I should have mentioned during our conversation. For stepper drivers and bridges, the ground plane is used primarily for heat disappation as compared to interference. So I believe the "dead bug" option might be excluded in this instance
Bruce
EDIT: A lot of the datasheets explain the use of a large ground plane extending from the ground pin to be used as a heat sink. However, perhaps the "dead bug" might even be better, I just don't know
Truly inspirational
Bruce
I don't know what it's "normally" used for, but you can get them in various width and thickness. I've just recently started using it to easily add power traces on prototype boards - especially nice when you have a bunch pull up/down resistors in a row. And since it's an adhesive, it could be much more convenient than using jumper wires and/or solder bridges. It seems to make prototyping a lot easier. I would probably recommend getting two rolls - one narrow and one wide. I currently only have wide, so sometimes I have to do a bit more cutting than I'd like.
-Mark
As mentioned in an earlier post, this makeshift ground plane would be primarily used for heat disapation. Of course I would tack it in place with solder or wire, but the thought of oozing adhesive worries me a little
Bruce
EDIT: Especially 3M adhesive
Bruce
Frank
Ah, right.. I never needed to use it for heat dissipation, but I have applied excessive heat with my iron on a few occasions and didn't notice any funny business from the adhesive.
