Which sensor to use?
My project is this; I live in an electric wheelchair, September will be 11 years. Everyone Ive ever met says the same thing, that you will run into walls and knock the corners off door jams, ding the frig., etc. etc. Unavoidable. So, I want to install distance sensors around the perimeter of my chair which will warn me when I am 3 inches away and interrupt the control signal to my wheels (stop the chair) at 2 inches away from an object. My thoughts are BS2 since I already made friends with her and have a BOE. I am thinking of using:
GP2D120 Sharp analog distance sensor probably 7 or 8 www.pololu.com/catalog/product/1136
8-Channel 12-Bit A/D Converter with SPI Serial Interface MCP3208-BI/P Parallax # 604-00062
Small Piezo and large LED.
Any comments, suggestions, criticism, etc. (Point the old cripple in the right direction advice) would be greatly appreciated. Thanks in advance.
I use a combination of sensors. I couldn't cut the power without voiding the warranty. So I used a separate power supply and warn my self with a vibration motor clipped to my waist. Thanks to all who responded.
My initial thoughts are to use a capacitance sensor.
The metal frame of the wheel chair would be the detector. As it moves along a path near obstacles. there would be a varying electric field surrounding the wheel chair.
I would use an RF frequency so that the surrounding would look like a ground path for the sensor.
The system would need four RF antennas: front , back, left and right.
The feed back for the operator would be an audio signal indicating left, right, back or front obstacle. The louder the signal the closer to the object.
The speaker could be mounted in the back of the chair near the operators head.
