Need music help for an old newbee
Irone
I copied a very simple program from "Whats a Microcontroller" to see how you put a pause in a song. When it did not work I replaced the battery with one I just bought a week or so ago. I then put in a debug for the noteLetter and the noteFreq. The breadboard has a piezo speaker hooked up to PIN 8 and ground. Even though the "P" has four zero's after it it still makes a sound. Here's my code. Will somebody tell me how to make a code box? This one did not work out too well!
Thanks Casey
' {$STAMP BS2}
' {$PBASIC 2.5}
' Bet with pause
Notes DATA "G","G","G","e","P","F","F","F","D","Q"
Durations DATA 8, 8, 8, 2, 8, 8, 8, 8, 2
WholeNote CON 2000
index VAR Byte
offset VAR Nib
noteLetter VAR Byte
noteFreq VAR Word
noteDuration VAR Word
DO UNTIL noteLetter = "Q"
READ Notes + index, noteLetter
LOOKDOWN noteLetter, [ "A", "b", "B", "C", "d",
"D", "e", "E", "F", "g",
"G", "a", "P", "Q" ], offset
DEBUG " ", noteLetter
LOOKUP offset, [ 1760, 1865, 1976, 2093, 2217,
2349, 2489, 2637, 2794, 2960,
3136, 3322, 0, 0 ], noteFreq
DEBUG " ", DEC4 noteFreq
READ Durations + index, noteDuration
noteDuration = WholeNote / noteDuration
FREQOUT 8, noteDuration, noteFreq
index = index + 1
LOOP
END
Thanks Casey
Unfortunately in this instance the "P" is still a note. You can change the duration of the "P" since it is considered a note and increase the pause to the duration of a normally played note. However, since all note durations are fractions of a whole note value, and you cannot individually specify whole note values for each note, you are limited on the length of your pause. You can add P's into your code, but I found that you still get the chirp from the speaker that you mentioned. Hopefully this helps!
'{$STAMP BS2} '{$PBASIC 2.0} '************************************************************************ '* Basic Stamp Activity Board Sample Program Player Piano * '* 9 September, 1997 (BS-2) * '* * '* This program demonstrates the use of the speaker and a couple of * '* look-up tables. Basically, the program emulates a one note player * '* piano. Hit the P5/P10 button to play the selected song. Hit the * '* P6/P9 button to select the next song. Hitting the P7/P8 button * '* selects the previous song. Hit 'Alt-R' and prepare to be amused. * '* Feel free to add songs as there is plenty of room on the BS2. * '************************************************************************ C CON 65 'Ridiculously low notes Db CON 69 D CON 73 Eb CON 77 E CON 82 F CON 87 Gb CON 92 G CON 97 Ab CON 103 A CON 110 Bb CON 117 BE CON 124 C1 CON 131 'Very low notes Db1 CON 139 D1 CON 147 Eb1 CON 154 E1 CON 165 F1 CON 175 Gb1 CON 185 G1 CON 195 Ab1 CON 207 A1 CON 220 Bb1 CON 234 BE1 CON 248 C2 CON 262 'Low notes Db2 CON 278 D2 CON 294 Eb2 CON 307 E2 CON 329 F2 CON 350 Gb2 CON 370 G2 CON 391 Ab2 CON 414 A2 CON 439 Bb2 CON 467 BE2 CON 495 C3 CON 521 'Middle 'C' Db3 CON 554 D3 CON 588 Eb3 CON 623 E3 CON 658 F3 CON 694 Gb3 CON 737 G3 CON 781 Ab3 CON 829 A3 CON 877 Bb3 CON 928 BE3 CON 980 C4 CON 1042 'High notes Db4 CON 1102 D4 CON 1163 Eb4 CON 1240 E4 CON 1316 F4 CON 1389 Gb4 CON 1476 G4 CON 1563 Ab4 CON 1658 A4 CON 1754 Bb4 CON 1856 BE4 CON 1960 C5 CON 2084 'Very high notes Db5 CON 2204 D5 CON 2326 Eb5 CON 2480 E5 CON 2632 F5 CON 2778 Gb5 CON 2952 G5 CON 3126 Ab5 CON 3316 A5 CON 3508 Bb5 CON 3712 BE5 CON 3920 C6 CON 4168 'Rediculously high notes Db6 CON 4408 D6 CON 4652 Eb6 CON 4960 E6 CON 5264 F6 CON 5556 Gb6 CON 5904 G6 CON 6252 Ab6 CON 6632 A6 CON 7016 Bb6 CON 7424 BE6 CON 7840 MaxNum CON 3 R CON $FF indx VAR Byte tune VAR Byte note VAR Word dura VAR Word INIT tune = 4 SHOW4: DEBUG "Bet with better pause",CR LOOP 'Get the next note to be played Song4 LOOKUP indx,[G5, G5, G5, EB5, R, F5, F5, F5, db5, 0],note LOOKUP indx,[250, 250, 250, 500, 250, 250, 250, 250, 500],dura IF note = 0 THEN DELAY 'it. IF note = R THEN REST FREQOUT 8,dura,note NXT indx = indx + 1 GOTO LOOP REST PAUSE dura GOTO NXT DELAY note = 0 dura = 0 indx = 0 PAUSE 200 STOPI only changed what was needed but, with a little work I think I can simplify it some.
