Sharing Tx (pin30) Rx(pin31) with other circuits that is using pull up. — Parallax Forums
tonyp12tonyp12 Posts: 1,951
edited 2011-07-18 18:44 in Propeller 1
I'm building a RTC module that will use pin 28 & 29 to share the I2C bus.
Pin-out is loosely based on Gadget Gangsters propboard.
So between pin28 and Vdd you have Rx/Tx pins, that I will use for RTC interrupt
Should I use pin 30 or 31?
For the RTC interrupt that is open drain,
active low and uses 10k-47k pull-up resistor
The INT pin stays low until all intflags are cleared by software.
So I don't want it to be a chance where you could brick the system if
you are still programming the setup with a USB/Serial cable and it
stops responding to proptool.
BTW is Rx/Tx open drain?, there are internal pull ups in the FTDI chip?
    P31 is the SI pin. This is the input pin on power up. IIRC the FTDI chip is not open drain either, so there is a potential conflict here.
    P30 is an output pin although I am unsure if it is made so until the download sequence is detected. It is not open drain, so you may also have a conflict here too.
