Where to buy your prototype PCB or sample lots? Please share your experience.
I have the need of buying prototypes these days for PCB board. I wonder who should I go to for the small volume to be printed. Some suggest me online is the best way out. They told me pcbwing and pcbtrain and pcbfinpo are the three good suppliers who accept small volume orders. Can anyone share their experience if they have tried witih the above listed shops before? I believe the sites are http://www.pcbwing.com and http://www.pcbfinpo.com Any advise is appreciated in advance.:nerd:
http://www.pcb-pool.com/
DorkBotPDX is hard to beat for small volume proto. $10 including postage for Qty 3 x 2 inch square boards. They are USA made boards with excellent specs (6 mil track/space, 13 mil via hole), and usually come with gold flash and funky purple finish.
The Italian one is quite good and offers a cheap proto service, but tailored to an Italian customer.
Olimex is feature limited, but you pay a fixed amount for a board, and you can stuff (almost) anything. You have limited drill size, and the drilll size is not the finished one. Tracks limits are 10 mils, or 8 with longer lead time.
On the other hand if you have different board designs, you can send the gerbers, and ask them to panelise and depanelise them for you, possibly sending a sketch showing how they should assemble the board.
I was able to send an assembled panel to PCb proto, in order to cut it at home to reduce the manufacturing price, and they accepted my request. So maybe asking the manufacturer and planning an easy to cut design you can reduce the cost...
Massimo
However, I have never tried wing, and none of them were better than finpo and express from my last few orders' exp. You can go for either of them if your board is 2-4L , if 6 L then finpo is a much better choice in every way.
