Counters, how to?
I am in the process of creating a weather station program using the Davis 6410 anemometer/wind vane. So far with the help of those here I have been able to get the wind direction and the string representation of that. I can also get the wind speed but would like to create an object for this and I think I need to have a seperate cog to handling the counting. My code for this is,
pub displaypulses
olds := 0
speed := 0
phsa := 0
waitcnt(cnt+clkfreq*5) '' Pause for 5s
term.str(string(13, "starting 01",13))
repeat
s := phsa
speed := (s - olds)
olds := s
'term.dec (phsa)
term.str(string(", s= "))
term.dec (s)
term.str(string(", speed= "))
term.dec (speed)
term.tx (13)
waitcnt(cnt + clkfreq * (225/100))
but I would like to call a function running in the object that would return the speed so I think I need to start this in its own cog and place the results in main ram but I don't know where to start. Where should I look for help? Thanks.
I don't think you need a seperate cog. All you need is take the counter value and divide by how much CNT has advanced.
Something like:
speedCnt := CNT repeat s := phsa speed := (s - olds) olds := s s := (s * (clkfreq / 100) * 225) / (CNT - speedCnt)P.S. It looks like you want your final waitcnt to be 2.25 seconds, but it won't be because "(225 / 100)" = 2
It would be better to divide clkFreq by 100 THEN multiply by 225.
Bean
{Station.spin} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 channel = 1 VAR long value, speed, dir OBJ davis : "Davis_6410" term : "FullDuplexSerial" PUB Init davis.start(1,2,3,6,@speed,@dir) term.start(31,30,0,19200) term.str(string(13, "Starting Station.spin ...",13)) repeat ' value := dir term.str(string(13)) value := (dir* 10)/114 term.str(string("Heading. ")) term.str(hdg2str(value)) term.str(string(13)) term.str(string("Speed, ")) term.dec(speed) waitcnt(clkfreq + cnt) 'wait 1 sec pub hdg2str(angle) | pntr pntr := @points case angle 000..011 : pntr += 0 012..034 : pntr += 4 035..056 : pntr += 8 057..079 : pntr += 12 080..101 : pntr += 16 102..124 : pntr += 20 125..146 : pntr += 24 147..169 : pntr += 28 170..191 : pntr += 32 192..214 : pntr += 36 215..236 : pntr += 40 237..259 : pntr += 44 260..281 : pntr += 48 282..304 : pntr += 52 305..326 : pntr += 56 327..348 : pntr += 60 348..360 : pntr += 0 return pntr dat points byte "N ", 0, "NNE", 0, "NE ", 0, "ENE", 0 byte "E ", 0, "ESE", 0, "SE ", 0, "SSE", 0 byte "S ", 0, "SSW", 0, "SW ", 0, "WSW", 0 byte "W ", 0, "WNW", 0, "NW ", 0, "NNW", 0is the station code and'' Weather Station Project wind direction (vane) '' Davis Model 6410 (10K potentiometer with 1M resistor in dead space) '' MCP3208 ADC (12 bit 8 channel) '' dpin = pin connected to both DIN and DOUT on MCP3208 '' cpin = pin connected to CLK on MCP3208 '' spin = pin connected to CS on MCP3208 '' mode not used, included for compatability with older program '' ========================================================= '' '' File............. Davis_6410_Vane.spin '' Purpose.......... Output wind direction '' Author........... Stephen Franklin '' Additional code.. Jon "JonnyMac" McPhalen (aka Jon Williams) '' Copyright (c) 2011 Jon McPhalen '' -- see below for terms of use '' Started.... 8 JUL 2011 '' Updated.... '' '' ============================================================================ CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq MS_001 = CLK_FREQ / 1_000 US_001 = CLK_FREQ / 1_000_000 ' Dpin = 1 ' Cpin = 2 ' Spin = 3 ' Mode = 0 VAR long Heading, s, olds, speedCnt OBJ adc : "mcp3208_fast" PUB Start (dpin, cpin, spin, apin, speed, dir) ' Initialize the MCP3208 with channel as the data input. adc.start(dpin, cpin, spin, 0) ' Configure counter modules. ctra[30..26] := %01110 'ctra module to NEGEDGE detector ctra[25..23] := %000 'PLXDiv to / 128 ctra[5..0] := apin 'anemometer input on pin frqa~ phsa~~ frqa := 1 ' Start the signal repeat s := phsa speed := (s - olds) olds := s dir := adc.in(1) waitcnt(cnt + (clkfreq /100)*225) {PUB getHeading (channel) Hdg := adc.in(channel) return hdg } PUB hdg2str(angle) | pntr pntr := @points case angle 000..011 : pntr += 0 012..034 : pntr += 4 035..056 : pntr += 8 057..079 : pntr += 12 080..101 : pntr += 16 102..124 : pntr += 20 125..146 : pntr += 24 147..169 : pntr += 28 170..191 : pntr += 32 192..214 : pntr += 36 215..236 : pntr += 40 237..259 : pntr += 44 260..281 : pntr += 48 282..304 : pntr += 52 305..326 : pntr += 56 327..348 : pntr += 60 348..360 : pntr += 0 return pntr DAT points byte "N ", 0, "NNE", 0, "NE ", 0, "ENE", 0 byte "E ", 0, "ESE", 0, "SE ", 0, "SSE", 0 byte "S ", 0, "SSW", 0, "SW ", 0, "WSW", 0 byte "W ", 0, "WNW", 0, "NW ", 0, "NNW", 0 } DAT{{ Terms of Use: MIT License Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. }}is the davis_6410 code
