What limits the maximum overclocking speed?
Assuming that the board was built for high frequency, and you were able to consistently cool the Propeller to a safe operating temperature, what limits the Propeller's overclocking capabilities?
Just something I was thinking about.
Microcontrolled
Microcontrolled
It is interesting to speculate about what you could get away with if you, say, immersed the Propeller in FlourInert and chilled it to 40 below...
Speed kills!!
I have proven that the Propeller hits a ceiling of ~120Mhz on 3V3 operation.
However if you increase the core voltage you can push it further, as seen in this video.
I'll be doing some more tests soon (that's before you ask me again Baggers!)
Coley
OBC
It is NOT JOKE on one of my PCB's I run Linus Demo with 15MHz PLL8 and it clocks correctly as faster in Seconds as % of increasing Frequency.
And I run it with standard Voltages (Maybe some 0.x V more that 3.3V)
Ps. I have even Movie to it -- But it is to big to post on forum
No cooling was required, all I did was modify a Hybrid PCB and used a DIP Prop.
I know Sapieha has had success with 120MHz with surface mount Props, I have found the tolerance of these to be much tighter.
Long story short, you need a DIP Package and a modified power supply to do this.
Oh BTW, I ran this for several weeks non stop and there was no apparent sign of degradation even though I'm sure there will have been some.
Temperature wise it didn't even get warm which was quite a surprise.
One thing I did note is that different instructions fail at different times, for example I can push further than 141MHz and still get a image but the code chokes at the double buffer copy stage so all you get is a static image.
Like I said, once I get some free time (when PropGFX demos are done) I will be doing a more definitive study.
Coley
Strangly( thankfully) the SD card was the only thing to survive, on a copy of a "Blade 2" (once it cooled down !)
