why i can create files on sd card only 32 files maximum?
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
obj
text : "vga_text"
fs: "fsrw2.6"
var
byte filename[13]
pub start
text.start (16)
fs.mount (0)
bytemove(@filename,string("REC_0000.CSV"),13)
repeat
increment (@filename , 13)
fs.popen (@filename , "w")
fs.pclose
text.str (@filename)
text.str (string(13))
waitcnt (30_000_000 + cnt)
pub increment(address,length)
' address is the starting address of the byte array for the string
' length is the total length of the byte array including the zero byte that marks the end of the string
address += length - 6 ' Change the address so it points to the rightmost digit of the numeric value.
repeat
result := byte[address] ' Use the implicit result variable for a temporary variable
if result => "0" and result =< "9" ' Check to make sure there's a digit character there
byte[address] := ++result ' Increment the character
if result > "9"
byte[address--] := "0" ' If greater than "9", set to zero and carry a one
next ' Repeat the loop
quit
pub increment is the function that increase number of filename that i found on this forum (thank you very much)
i want to test how many files that i can create on sd card with my code
and the result is 32 files
i don't understand why i can create only 32 files .
and how to create more than 32 files ?
i'd be grateful to anyone who could make this clear to me
thank you very much in advance
sorry for my english
my sd card is fat32 format
obj
text : "vga_text"
fs: "fsrw2.6"
var
byte filename[13]
pub start
text.start (16)
fs.mount (0)
repeat
fs.pclose
repeat
if result > "9"
quit
Your increment methode looks wrong, but it's difficult to say without indentions. "next" is not necessary to repeat a loop.
You need to capture the aborts from the fsrw methodes, this is done with a backslash before the methode call. And you should also test the return value. Most fsrw methodes return zero if succesful, or a negative error number otherwise.
Try it with this code: (I've only tested the increment methode)
_clkmode = xtal1 + pll16x _xinfreq = 5_000_000 obj text : "vga_text" fs: "fsrw2.6" var byte filename[13] pub start text.start(16) \fs.mount (0) bytemove(@filename,string("REC_0000.CSV"),13) repeat increment (@filename , 7) \fs.popen (@filename , "w") \fs.pclose text.str (@filename) text.out(13) waitcnt (30_000_000 + cnt) pub increment(address,pos) ' address is the starting address of the byte array for the string ' pos is the position in the byte array of to the rightmost digit of the numeric value address += pos ' Change the address so it points to the rightmost digit of the numeric value. repeat result := byte[address] ' Use the implicit result variable for a temporary variable if result => "0" and result =< "9" ' Check to make sure there's a digit character there byte[address] := ++result ' Increment the character if result > "9" byte[address--] := "0" ' If greater than "9", set to zero and carry a one else quitAndy
ElectricAye
- thank you . i will post my code on your way on next time.
Ariba
- thank you for editing my code but i think my pub increment is work for sure
i have already tested by running number from 1 to 9999 and it's work
about my code, my vga screen stop display filenames at REC_0032.CSV
and i get 32 files on my sd card
i have tested your code now . filenames are displayed continuously even i unmount my sd card
i unmount my sd card when REC_0048.CSV displayed
i wish i get 48 files on my sd card but it's only 32 files too
is format of sd card involve?
==sorry for my english==
pub start | err text.start(16) err := \fs.mount(0) if err text.str(string(13,"Mount error: ")) text.dec(err) bytemove(@filename,string("REC_0000.CSV"),13) repeat increment(@filename ,13) err := \fs.popen(@filename , "w") if err text.str(string(13,"Open error: ")) text.dec(err) err := \fs.pclose if err text.str(string(13,"Close error: ")) text.dec(err) text.out(13) text.str(@filename) waitcnt (30_000_000 + cnt)Andy
my vga screen show this :
REC_0001.CSV
REC_0002.CSV
REC_0032.CSV
open error: -2
REC_0033.CSV
open error: -2
REC_0034.CSV
open error: -2
what open error: -2 mean??
... err := \fs.popen(@filename , "w") if err text.str(string(13,"Open error: ")) text.dec(err) else \fs.pputs(@filename) ...ariba : thank a lot for help . i will try it.
kwinn : i have tried to format already but it's also created only 32 files too.
mark_t : i understand what you said now . is fsrw have any methods to create files on other directories ?
Has code in there to fix your problem. Read the APP note first.
i'll try to edit my code and tell you the results.
thanks
