Can someone answer this SX question?
wass
I know that this is the wrong place to ask a question about the SX, but.....
I posted what seems to me to be a straightforward question on the SX forum a couple of weeks ago and haven't received any replies. Perhaps someone here can help. Here's the link:
http://forums.parallax.com/showthread.php?132401-Command-Line-Programing-of-SX
Katie
Katie
Look at page 19. It seems you have found nearly all of them already. Also note that the manual advises you to generally avoid using these switches. If you want to do something fancy, you need to use what Windows has to offer in command line programing.
http://forums.parallax.com/showthread.php?96105-SX-Key-IDE-Beta-v.3.2.7&highlight=command+line%3A
Katie
If you just want to locate and separate the command for use as a stand alone loader, I think it is pretty straight forward when using an RS232 port. It might be more of a challenge when using and USB to RS232 adapter, but this really needs to all be done in Windows. If there is a working SXKey.exe, that is about all you likely need.
The noted options and bug fixes were in a beta version that was never released.
Katie
