Copper or Brass for a heat sink?
I can't decide on what metal to use, copper or brass for a heat sink on a L293D H-Bridge. Its going to span the 4 GND pins on the chip and extend out an undetermined distance.
So before I go to the hardware store and stand there trying to decide
I thought I would ask maybe some one can give me a reason to use one or the other. I know its not that important but I can't seem to make a decision. :depressed:
Thanks for any input
-Ron
─┤1 (B) 16├─
─┤2 15├─
─┤3 L 14├─
GND ─┤4 2 13├─ GND
GND ─┤5 9 12├─ GND
─┤6 3 11├─
─┤7 D 10├─
─┤8 * 9├─
-Ron
I need a metal that will accept solder (solder doesn't stick to Al or does it?) so the heat will transfer from the pins. I plan on putting it under the board or between the IC and the board, I am still not sure.
If you look at the expensive heat sinks available they are often made of copper.
I should be able to give you a better answer based on heat capacity and how fast heat transfers through the material (I majored in chemistry), but I don't have all the data to compare.
I bet pretty much any metal will work. Metal is a good conductor of heat. Some are better than others but I'd suggest just buying something that is the right size and not too expensive.
Duane
All my attempts to solder to Al have failed.
Aluminum has the best heat conductivity. Copper comes in second and brass comes in last (of the three).
Because copper is expensive, as with the tabs on regulators and power transistors, often you'll have a piece of copper that you can solder to, then the piece of copper is bolted to a substantial aluminum heatsink with a little bit of heatsink compound between the two surfaces.
Thanks All
-Ron
Not in this case Leon its a 16 pin DIP going on a perf board.
-Ron
