Sensing 12V?
Hugh
Greetings,
I am looking at a potential new project based on a protoboard. Because it involves sensing the position of a switch or two on a vehicle, I need to be able to sense the presence (or not) of 12V DC.
Dare I go down some simple route involving resistors, or am I staring down the barrel of opto-isolators, etc.?
Advice, opinions and experiences (good or bad) gladly received,
Thanks in advance,
Hugh
Thanks in advance,
Hugh
Automobile electrical systems are very very noisy. Be sure to use adequate filtering and shielding if you want to run the Protoboard off the +13.8V power supply of the auto.
Onward and upward!
Hugh
No, I don't reckon that's enough protection, expect big inductive spikes on the 12V line (I mean BIG) and use schottky diodes to prevent the pin going above 3V3 or below 0V Remember the 12V system is connected to many largish electric motors and inductors (the horn for instance). So perhaps 47k/10k divider and two schottky diodes per pin, then possibly a schmidt-trigger to condition the signal. And even then debouncing in software would be wise.
Ditto. Also with Mike's comment. A good choke ahead of the filter and PS caps helps a lot as well.
