Golden Ratio. Measure of appeal
We are designing a new product at work so I was curious to see if this product met the Golden Ratio criteria. I was astounded to find that it did indeed measure close to the Golden Ratio. I am curious as to see if anyone of you have used the Golden Ratio concept in any of your work?.?.?.?
Cheers,
The other side of it is that a 72 degree angle crops up in the Golden ratio. This has given us the Penrose Tiles which are based on 72 degrees and 36 degrees. But the fun doesn't stop there.
The past few decades began to recognize that crystals were not all based on a rectangular system of tidy repetition. We now have new horizons in material science based on the quasi-crystal, which is a three dimensional representation of the the Penrose Tiles.
In other words, we are still finding that pesky Golden Ratio cropping up in new information about nature. It is a transcendental number, along with Pi. And there is just something I can't resist about transcendental numbers. They seem able to continually surprise us with new insights.
Now I indeed need to contemplate my navel positioning.
The couple and many of their friends are musicians. I've been thinking about a way to bring the sequence to life musically when I give my little speech. Musical tones in Fibanacci ratios are particularly rich in subharmonics (beat frequencies), and especially so the golden ratio as the limit. Attached is a demo that works on the Parallax demo board, to play two mixed tones on each of the stereo audio channels. It does not do much yet, and I'm not sure where to take it as an entertaining allegory for musicians being married. But there you have it. It is set up to play a ratio of 8 to 5 on one channel, and a ratio of 13/8 against (1 + root(5))/2 on the other.
A transcendental number is one that is not the root of a polynomial in any degree. A number that is the root of a polynomial of any degree with integer (or rational) coefficients is called an algebraic number. A transcendental number is one that is not algebraic. It is very difficult to prove that a number like pi or e is transcendental, despite the fact that it is known that most numbers are transcendental. That is the set of algebraic numbers are of measure zero on the number line and most of the "space" is occupied by transcendental numbers.
Humble pie once again.
Nonetheless, it is one of my favorite constants. Let's say it is a 'metaphysical constant' of sorts; along with pi and e and a few others that seem to resurface again and again in nature.
I agree, the golden ratio is very special and appealing. Another of its many properties is that its continued fraction is the slowest converging of any real number.
That has interesting consequences for numerically controlled oscillators (as in the NCO mode of the Propeller counters). A frequency in that ratio to the clkfreq has the greatest amount of jitter, the most subharmonic content in its output.
I sailed off into contemplation of 3-D Penrose Tiles and Quasi-crystals after posting my comment. I suspect that there is something major to be discovered there.
So much of our present knowledge is based on Newton and his calculus is based pretty much of the summation of cubes and rectangles. One might say that they are the fundamental module of his mathematics and it is highly dependent on a Cartesian co-ordinate system. I do admit that there are also conversions to Polar notation and circular rotation, but it still starts out with the square and the cube to build its world.
But if you look at Penrose Tiles, you are presented with an entirely different fundamental modularity. Instead of one module (the rectangle or cube), you have two forms of tiles that provide fundamental modules to fill a plane or space.
Buckminster Fuller's geodesics are a spherical modeling based on the Golden Section and reflect a relationship with the 3-D Penrose Tiles. The icosahedral and dodecahedron have Golden Section relationships within them.
Could it be that the 3-D Penrose Tiles might be the foundation of a new better system of calculus, which is based on the Golden Mean? I dunno.
But if it is so. you heard it first on a Parallax Forum.
http://www.goldennumber.net/quantum-E8.htm
http://www.geom.uiuc.edu/apps/quasitiler/
http://comdig.unam.mx/index.php?id_issue=2007.09#26855
Here is another page of profundity. While Mark T is able to use the jargon correctly, that jargon tends to go over the top of people's heads. Images seem to help people intuitively recognize its worth. And it isn't all about rectangles. There are spherical relations in the microcosm and the macrocosm. Something related to Physics on a profound level is going on.
Yes indeed, the Arab did something similar to Penrose Tiles, long before he copyrighted/patented his work. But it seems that was based on a 10 fold geometry, not Penrose's five-fold work. The fact that these tiles are aperiodic makes it hard for us to visually them extending infinitely in all directions, but they can and they may model interlocking/overlapping spheres of influence throughout the universe.
