SayIt Module GUI's Programming Program for BS2
I'm wondering if there is some place where I can find the "programming program" (I think it's referred to as the "Bridge Program") that the stamp runs when you train it with the SayIt GUI? I want to add it as a slot in my voice controlled home automation system (with some modifications) so I can change commands/retrain in-circuit.
Thanks!
PS., I checked the code in the SayIt GUI's data folder, and found several items, but none appear to have the bridge program functions (although RN1 looks pretty interesting - a very substantial robot control program!) So... still looking for that Bridge Program code!
Thanks!
' {$STAMP BS2sx}
' {$PBASIC 2.5}
' COM Parameters
COM_RX PIN 0 ' rx pin
COM_TX PIN 2 ' tx pin
COM_SPEED CON 240 ' baud 9600
COM_10MS CON 25 ' 10ms unit
' Protocol Command
CMD_BREAK CON "b" ' abort recog or ping
CMD_SLEEP CON "s" ' go to power down
CMD_KNOB CON "k" ' set si knob <1>
CMD_LEVEL CON "v" ' set sd level <1>
CMD_LANGUAGE CON "l" ' set si language <1>
CMD_TIMEOUT CON "o" ' set timeout <1>
CMD_RECOG_SI CON "i" ' do si recog from ws <1>
CMD_RECOG_SD CON "d" ' do sd recog at group <1> (0 = trigger mixed si/sd)
' Protocol Status
STS_AWAKEN CON "w" ' back from power down mode
STS_ERROR CON "e" ' signal error code <1-2>
STS_INVALID CON "v" ' invalid command or argument
STS_TIMEOUT CON "t" ' timeout expired
STS_INTERR CON "i" ' back from aborted recognition (see 'break')
STS_SUCCESS CON "o" ' no errors status
STS_RESULT CON "r" ' recognised sd command <1> - training similar to sd <1>
STS_SIMILAR CON "s" ' recognised si <1> (in mixed si/sd) - training similar to si <1>
' Protocol arguments are in the range 0x40 (-1) TO 0x60 (+31) inclusive
ARG_MIN CON 64 ' 0x40
ARG_MAX CON 96 ' 0x60
ARG_ZERO CON 65 ' 0x41
ARG_ACK CON 32 ' 0x20 'TO READ more status arguments
Dave
I haven't use the Basic Stamp for several years so I don't know of to write the program in Pbasic. I don't think it would be hard.
Duane
Dave
You want to check for serial input from both the computer and the Say It. Any input received gets outputted to the other device.
You want to translate this part in to PBasic. I've added some comments to hopefully make it easier to understand. Com[0] is used to communicate with the PC. Com[1] is used to communicate with the Say It.
Technically, you don't need the computer to reprogram the Say It. All the commands the computer issues to the Say It could be issued from a uC.
Duane
And I agree on the "ease of serial communications" thing - I have been so thoroughly spoiled by SERIN and SEROUT that it was a shock to me when I found out that I had to include entire propeller objects like Full Duplex Serial to handle something I could do in a single line with the stamp. Even though I recognize that the Stamp, in reality, has it's equivalent of FDS built in as code somewhere, my mind started thinking that I could wind up filling up the prop's entire memory with the stuff I needed to include! :-) But now I have seen the complexity of what the prop can handle, and I'm hooked - but still kind of feeling my way through clumsily.
Thanks for this info, I hope to be able to test it out soon (I'm away for a few days).
Dave
