$2.46 Battery Voltage Digital Readout
http://cgi.ebay.com/2S-6S-RC-Lipo-battery-portable-Voltage-Indicator-Meter-/140564441139?pt=Radio_Control_Parts_Accessories&hash=item20ba4b2833
$2.46 shipped from China. Designed for 2-6 LiPo batteries, not sure if it can be adapted for other battery chemistries or as a general DVM.
Check this seller's other interesting R/C-related items at http://shop.ebay.com/planemodel-a/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p3686
I opened it up and reconnected it with a thick copper wire. Then, a few weeks later, I did the same thing and it blew again. After fixing THAT I managed to blow it AGAIN a few weeks later! The knob traces were completely fried off the board, and I had to throw it out.
So, great for low voltage, not so good for high. :-)
-- Gordon
The third time blew the knob off. Good times! :-)
Pourquoi en fran
video at http://www.youtube.com/watch?v=TpTFLZngoNA
Somewhat similar to this $13 "Cell Spy" unit: http://www.youtube.com/watch?v=1zleStIMkbY but cheap enough to be built in to a project.
These are widely available for ~$2.31 on Ebay: http://www.ebay.com/itm/RC-Voltage-Lipo-Battery-Meter-Indicator-2-6-cells-LED-/290495353747?pt=Radio_Control_Parts_Accessories&hash=item43a2df5393
TTYTT, I recognized the readout from ExDxV's latest video at http://www.youtube.com/watch?v=F3u0rTNBCuA He used it this way and realized I never followed up on my original post. So thanks for the unintentional kick in the pants, ExDxV!
Have you ever found any documentation/specs on these gizmos? I wonder if they would work with 12 volts...
JK, I'll smoke test it right now...
Phew...!
Great! How long does shipping take from China??
Not too bad - I just ordered two.
Thanks for testing it with 12V!!
- Ron
So have you tried 12V as a single cell?
BTW, I agree, these things are great.
I told you I used the one you gave me with a Nerf Vulcan I modified to use a 3-cell LiPo? I attached the read out to the side of the gun so I could monitor the voltage of the cells. It looked like some futuristic energy weapon.
We had a fun Cub Scout Pack Meeting with one cub defending a flag with the gun as the other tried to capture it (the flag). It was a blast! (pun intended)
I'm going to get a bunch more of these things. They'll probably pay for themselves by the LiPos they will save from being drained too low.
No, I'll leave that to a braver, richer man who likes the smell of 'lektrik smoke in the morning. The Ebay description says 2-6 cells, and the intent is 3.7V lithium cells, so it should be capable of reading up to at least 6x3.7=22V, though not necessarily in one step. From what I gather, the device itself is powered from the first 3.7V cell, so the limiter is whatever its regulator can handle. Besides, it's far cooler to have it scroll thru multiple voltages!
Preaching to the choir here. I have a bunch of 6-cell LiPos I use with my helicopter. I plan to get at least one of these readouts for each device I have that use LiPos or LiIons.
There are a great find erco.
The meters do consume some power themselves. The chip on the back got barely warm in my tests. If it uses a linear regulator (which would be dumb by today's standards, but who knows), then it could get warmer the higher first cell voltage is. So don't let your meter drain your fancy LiPos!
Yes, I wouldn't leave the readout attached all the time. I might leave one on while I'm actively using the device in question. I'll unplug them when the device isn't being used.
At the price they sell them, I doubt they're using a switching regulator.
Amanda
The ground was hooked to pin0, 4.5v to pin2 and 1.5v to pin1.
The display shows No1=2.15 No2=4.27 ALL=6.35
A second one shows No1=2.15 No2=4.35 ALL=6.43
Am I missing something here? Where is it getting over 6 volts with 4.5 volt supply?
EDIT: If I switch pin1 to 3v, No1=4.27 No2=2.15 ALL=6.35
It appears that the "ALL" value might just be a sum of the individual readings, not a reading of all the cells in series...
But the values are high in any case.
Actually I think they get power from pin 2 but it seems 4.5v is not sufficient.
I tried 6V across pin 2 and I get more realistic values:
with 1.5v on pin 1, I get No1=1.49 No2=4.66 ALL=6.08
with 3v on pin 1, I get No1=2.98 No2=3.17 ALL=6.08
