Beginning robotics...sumo bot?
Hello,
I purchased and completed the beginner's Boe-Bot kit, and now I am looking for more projects to complete. I still consider myself a beginner but I'd like to learn more about robots/electronics. I'm looking at the SumoBot kit now - I'd like to try it, but there are two bots in the kit. Is it necessary if I already have the boe bot, and if not, can I make my boe bot into a sumo bot? Thanks.
RK
RK
Mike's advice is always good. The sumo bots are really designed for Robotic Sumo Wrestling (throwing each other out of the ring so to speak), therefore they should be of the same style, shape, and weight.
There's other types of competition too. For example, as suggested, you could both get boe-bots, and QTI sensors and then have a line following "competitions" (he whose programmed bot follows the line in the least amount of time wins, etc).
Or you could use Ping (sonar) sensors to detect objects - like navigating walls in a maze or have an obstacle course where your Boe-bots have to find their way through without bumping into things...
Just a couple of "next step" ideas - the cool part though, is that you're having fun with Robots and your Dad!
-Matt
Take your pick for types of "Garage Competitions"
The largest European robotic event, RobotChallenge 2010. Many good examples here.
Funny Sumo Sumo Bots Actually this is a bit advanced, but it's funny.
Normal home built Sumo's Or somewhat normal because most sumo's are homemade.
Japanese Line Follower Competitions They are so extreme in Japan.
More great Sumo Bot Competitions. Advanced, maybe they are tired of slo bots
A Competition in California Check out the Sumo Bot Rules for all recognized classes
A List of Competitions held all over the place
Explore you tube for a while. Invite your dad to explore you tube. Chances are, you will find something you want to try.
Scavenge your old toys for wheels and Dad's old VCR for other great stuff. Use balsa wood to build your first bots with, and use the BS2!
