Latching Relay Goldmine
Electronic Goldmine has DIP DPDT latching relays for $1.50. http://www.goldmine-elec-products.com/prodinfo.asp?number=G2011
Data sheet at http://pdf1.alldatasheet.com/datasheet-pdf/view/197272/OMRON/G6HU-2.html
They're more like $8-9 elsewhere: http://www.newark.com/jsp/search/productdetail.jsp?SKU=02H7528
These relays are latched on by a brief pulse, and latched off by another brief pulse. So your motor or external circuit remains on, even though there is no power being consumed by the relay to keep it on. Very economical on power consumption, latching relays like these are used in battery powered applications for long life. That's how your heater thermostat works for a whole year on 2 AA batteries.
The only tricky aspect is that you need two I/O pins to control the relay, but you can multiplex them easily. Worst case, for N relays, you need N-1 I/O pins, or you can do binary pin combinations and use fewer.
from http://www.avrfreaks.net/index.php?name=PNphpBB2&file=printview&t=15391&start=0 :
You are right the relay is set by + on Pin1 and - on Pin 10, and vice versa for reset.
http://www.newark.com/nte-electronics/r74-11d1-3sm/signal-relay-dpdt-3vdc-1a-through/dp/02H7527
But not the ones erco linked to. Right? I read in the datasheet "Must operate voltage" equals "75% max. of rated voltage." 75% of 5V is 3.75V.
You'd need to buy the ones 3sam linked to to use with 3.3V.
So could a Prop drive the 3V version directly? The datasheet says "Rated current | 33.3mA." A Prop should be able to handle 33.3mA. So if I add a diode across the coils it should be okay?
I think I'll get some of the 5V since the price is so good.
I've used these type of relays before. Two of the ten pins are not connected. I have a bunch of eight pin sockets so I just left the nc pins hang over the side. I think I had to modify the socket a little; the relay's body is wider than a normal IC. I'm using these in my sprinkler controller.
Thanks for the tip erco.
Duane
I got distracted when I posted and I forgot to include the specs. At 5V, they only draw 20 mA, so you could run them directly and continuously, even though you don't use them that way. Blip them for 100 ms and that's plenty. And the switched contacts are rated for 1 amp. Sweet...
AFA 3.3 V operation, that "must operate at 75% voltage" spec is probably conservative. I have lots of my favorite Aromat 5V DIP relays, which are designed to operate off operate off 20 mA, 270 ohm coil. MOST of them operate reliably directly from a Stamp Homework board, which is 5V with inline series 220 ohm resistors. So they are operating off of just over 2.7 V. I bet most of these $1.50 relays would trigger off 3.3V, even if you had to hand pick them.
My Aromat relays have built-in flyback diodes, but those are not latching relays like these Omrons. The only thing left to determine is whether flyback dodes are necessary or can even be used on these Omrons. Since you apparently reverse polarity to the same two pins to switch the relay, traditional flyback diodes in parallel with the coil would short out in one direction.
I think you need the flyback diodes with these.
You want to use two diodes per relay. Each coil pin should be connected to the anode of its own diode. The cathodes of the diodes are both connected to Vdd. I think this is the way I hooked up my latching relays. Whatever I did, it worked. I'll take a look at the board an make sure. But the method I described make sense in my mind.
Duane
6 relays on 4 pins;
10 relays on 5 pins, etc.
For instance for 5 pins, there are 4+3+2+1 unique combinations. A simple BS1 with 8 pins could switch 28 relays!
This is essentially using the relay's latching feature as external "memory".
https://www.amazon.com/OMRON-ELECTRONIC-COMPONENTS-G6HU-2-DC5-SIGNAL/dp/B011NKJQ1Y
http://www.ebay.com/itm/1-Channel-5V-Latching-Relay-Module-with-Touch-Bistable-Switch-/282405746030
Did you try that with both the Relay and Prop warmed up ?
