my call rutine of getting single byte from cog ram long
tonyp12
Most of the time, I simple use longs even if the data always are less than the value of 256.
But maybe you try to save space and sometimes you are simple forced to have the data as bytes.
So I come up with this routine, you set the byte you want in bytepnt before you make the call.
Then it comes back with the answer in mybyte.
It does not trash bytepnt, so it can used as a global variable in your code that you add/sub to etc.
I have not tested it, but it should work.
Any shorter routines you Prop Heads have come up with?
main mov bytepnt,#3 'just an example
call #getbyte
movs dosomething,mybyte 'just an example
jmp #main
getbyte mov bytepntbuf, bytepnt 'don't trash bytepnt
shr bytepntbuf,#2 'divide by 4
movs findbyte,#data 'start location of our byte table
add findbyte, bytepntbuf 'add the divided-by-4 byte pointer
mov bytepntbuf, bytepnt 'start with a fresh bytepointer
and bytepntbuf,#%11 'keep only the 2 lower bits
shl bytepntbuf,#3 'multiply by 8
findbyte mov mybyte,0-0
shr mybyte,bytepntbuf 'find the right byte from a long
and mybyte,#$ff 'keep only the lower 8 bits
getbyte_ret ret 'return, with answer in mybyte
data byte 0,10,20,30
bytepnt res 1
mybyte res 1
bytepntbuf res 1
by using ror as movs only transfer the lower 9bits.
getbyte mov bytepntbuf, bytepnt 'don't trash bytepnt ror bytepntbuf,#2 'divide by 4 but roll lower two bits to top. movs findbyte,bytepntbuf 'initiate the start location add findbyte,#data 'add the start location of our byte table shr bytepntbuf,#28 'shift the upper two bits down (edit: use 27 if Ariba is right) ... the rest is the same from findbyte above.The shr must be 27 not 28 (30-3)
main mov bytepnt,#3 'just an example call #getbyte movs dosomething,mybyte 'just an example ... ... jmp main getbyte mov bytepntbuf, bytepnt 'don't trash bytepnt ror bytepntbuf,#2 'divide by 4 movs findbyte,bytepntbuf 'write lower 9 bits as source address add findbyte, #data 'add start location of our byte table shr bytepntbuf,#30-3 'multiply 2 lower bits by 8 findbyte mov mybyte,0-0 shr mybyte,bytepntbuf 'find the right byte from a long and mybyte,#$ff 'keep only the lower 8 bits getbyte_ret ret 'return, with answer in mybyte data byte 0,10,20,30 bytepnt res 1 mybyte res 1 bytepntbuf res 1Andy
So the long used up by op-code 'call' would not cancel out the space saving.
And that your table is at least 12 bytes long.
That I can add 1 or 2 to the bytenct as my code checks for specific char etc is useful and maybe then sub 1.
Without thinking about byte boundery in a long.
Compared to this cludge I used first, were I loop the shifter from 0-to24 and reset if it hit 32 and add 1 to longcnt
Does not easy allow to look forward two bytes and then back up one.
if_nz add byteshft,#8 'if not a zero, prepare next char for next tim cmp byteshft,#32 wz if_z add loop1,#1 if_z add testdot,#1 if_z mov byteshft,#0
