Propeller Chip Frequency
For a single chip, running various programs, what can be said about determining the overall combined frequency radiated by the chip (in terms of RF, i.e. received by a radio in close proximity)?
Is there a mathematical relationship, frequency vs running code?
I want to read "combined" RF frequency from a single chip (without touching the chip) and generalize what the chip is doing internally.
Thanks sincerely.
Thanks sincerely.
The wiring to the chip will do most of the radiating, not the chip itself.
It's worth noting that Morse Code developed in a similar fashion. The original equipment was designed to mark a paper tape that would subsequently be read. With time, operators found they could pick up the content simply by listening to the noise that the tape marking machine made. Eventually they dispensed with the paper.
It's lke SONAR and submarines. Theoretically, you could derive the signature of a submarine from the design and massive calculations but until you have heard a specific sub and captured it's signature you can only estimate and assume. You may be able to determine if a signature is from a certain class of boat but you wouldn't know WHICH specific boat unless you had that boat in yoru library.
Same thing for chips, you may be able to differentiate between a BS2, a Propeller and an Atmel but overal RF radiation but probably not much more than that.
http://en.wikipedia.org/wiki/LEO_%28computer%29
It incorporated two divide by 10 stages, using unijunction transistors created from an NPN-PNP pair of BJTs, UJTs had just been invented and weren't yet available commercially. I was told that a conventional digital divider was too expensive.
The earlier valve-based LEO machines were so slow that an amplifier could be connected directly to the CPU.
