Mini LCD A/V Color Display compatible with an old Apple 2 computer?
I have an Apple 2e computer and I'm looking for a tiny color monitor that I can use with it. Would anyone happen to be using Parallax's Mini LCD A/V Color Display with an old computer that cares to share their experiences with it?
I _think_ it would work but I'm afraid that I don't know much about displays.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/603-32000/List/0/SortField/4/ProductID/337/Default.aspx
-dan
Vertically, most displays will work great, because the Apple only outputs a non-interlaced, simple display of 192 lines.
Some displays have trouble with the signal not being interlaced. Somebody here bought a LCD that wouldn't display our simple, Apple like drivers, and we isolated the problem to the display needing a interlaced input signal. Apples won't display on those.
I've a //e platinum, and every display I tried worked well so far. I don't think there are many that require the interlaced signal.
Double high-res and 80 columns won't do well on the Parallax LCD. The display needs to have more horizontal pixels. LCD TVs, and most ordinary CRT TV's will do ok at the 80 column display, but it may be hard to read. YMMV
Double high-res graphics will probably work on the Parallax display, because those are almost never used on a per-pixel basis. Some of the GUI type programs for the Apple, like GEOS, did use the double high res as a 580x192 pixel desktop screen, but most programs took advantage of the NTSC color artifacting that happens, using the display as a 140 pixel x 192 pixel, 16 color display. You should see that run well on the Parallax display, if it's the lower resolution one I'm thinking of. Unless I am mistaken, Parallax has shipped a coupla different displays. The first one was fairly low resolution. I don't know about the second, or maybe follow on ones.
Either way it all goes, the worst case is you see a smudged display. Plug it in and try it!
Nice machine! What do you plan to do with it? I'm setting up to connect a Propeller to mine.
You say that there is an old apple II version of GEM? I am interested. I was only aware of GEOS, Apple II Desktop, and GS/OS as GUIs go for the apple II series pre 1994.
Ah OK. there was a GEM port for the Apple Lisa though, just not the Apple 2 series.
