New (DSO203) portable oscilloscope!
A new portable oscilloscope is on the way: DSO203
Some of the features:
30MHz analog bandwidth
Two probe connectors, 4 inputs & 4 tracks (2 analog 2 digital)
3" 240
3" 240
""is that a iphone . nope its my O-scope ."
Is there a Propeller inside? If so, it should have a little logo sticker on it to encourage us.
If 1 MHz bandwidth is enough for you, 1Msps still doesn't fit the bandwidth. 1 Msps equals 100 kHz bandwidth.
Nick
http://www.mouser.com/ProductDetail/STMicroelectronics/STM32F103VCT6/?qs=sGAEpiMZZMvu0Nwh4cA1wf8bzqBH8XzckwyPFT1Ph04%3d
►The AD9288-40 Overclocking to achieve 72M+72M sampling frequency, so that the maximum single-channel sampling rate up to 144M.
►Analog channel circuit using unity gain> 150MHz op amp, so the actual 30MHz analog bandwidth is expected to do more.
The actual page is about ARM DSO Nano Pocket Oscilloscope ($43.20+$29.95) the ARM DSO Nano, has a 1Mhz bandwidth,...
Look at the middle of the same page, under: Advertisement: New Products, Coming soon!!!
This one is about DSO203 oscilloscope which has the actual 30 Mhz bandwidth.
Retail price: 199USD
Beta test price: 159USD
DSO Quad:
Two 36Mhz analog channels and two digital channels
Signal Generator
Auto Measurement
Various Triggering Option
Easy waveform storage
Firmware upgrade
Read more at: http://www.seeedstudio.com/depot/preorder-dso-quad-beta-test-p-736.html?cPath=174
now, i have received a new DSO203, it is in good condition, they packed it with a stronger box.
i highly recommend this item, if you are looking for similar products, you can think about this.
i bought it here: http://www.diyertool.com/dso203-pocket-sized-digital-oscilloscope-arm-dso-nano.html
Best wishes,
Sharon Feerick
http://www.sparkfun.com/products/10388
Bean
Nice little unit.
First impressions:
The digital probe connectors are super tight. I had to use pliers to unplug them. They'll probably loosen up with use.
1 or 2MHz is about the analog input limit for square waves. Above that and they really get rounded off.
The digital inputs are good to about 1MHz too. Even at 1MHz the duty is really off showing about 75% instead of 50% and gets worse at higher frequencies.
I updated the firmware and it's not too hard, but it took awhile to figure out the correct files to use.
It does NOT charge when on. Kind of a bummer.
Overall I am impressed with it. Quite nice for $225.
If anyone has any questions about it just post them and I'll try to answer them.
Bean
You can do a review? Something like this:
http://www.youtube.com/watch?v=59hdyXSYqsE
Thank you.
But I just need a normal oscilloscope which I can detect waveforms at around 1~100kHz frequency range. Could this "2Msps Sampling Rate ARM DSO Nano Pocket Oscilloscope" cut it?
I have bought a DS0203 quad, and as you say when I try to display a square wave with frequency greater than 1MHZ, what I see is a rounded form or an distorted wave that not seems being a square wave.
But the specification for DS0203 quad say: "72Mhz analog bandwidth" !!
So, do you have any suggestions to resolve this problem, or It's a limit for this device?
Please apologies for my poor english.
Many thanks
Cristian
Thanks for your replies. Ok I understand the problem but I have used an input signal with frequency of 4MHZ that is much smaller than 72MHZ.
At the start I thought the the problem was in my circuit, so, to eliminate any doubt I have connected the DSO203's output (generating a square wave with frequency from 1MHZ to 4MHZ) to the CH1 input and what I see on display is the same result: a rounded form or an distorted wave that not seems being a square wave.
but with a sampling rate of 72Ms/s the bandwidth is about 36MHz. And my square wave has 4MHz of frequency.
I have repeated the same measure with an old oscilloscope (bandwidth 20MHZ ) and I saw the square wave perfectly.
Anyway, thank you for your patience and courtesy.
36MHz would be the bandwidth LIMIT. The actual analog path would have to be perfect (no attenuation at any frequency) to achive that.
The DSO203 is good to about 1 MHz to 2 MHz, after that signals get very rounded. This is caused by the analog path, not by the digital sample rate.
It's kind of like having a digital camera with a poor lens. No matter how high the megapixel resolution is, the image will always be blurry.
Bean
Nevermind, figured it out lol long day.
I like the 6 digit frequency counter.
http://www.uni-trend.com/UTD2102CEL.html
eBay suggests prices of ~US$340, vs $180-$200 for DSO203, depending on case choice.
I am new to this forum and I recently bought a DSO203 and I am having som questions that maybe you experts could answer, and I think that others have the same questions too.
The first thing I saw on my dso was that when I set V/div on, for example, CH A to 1V it measures just fine but when increasing the voltage/div it starts to give some faulthy values. When I connect CH A probe to itself it should show 0V but over 1V/div it shows more than 0V. At 10V/div it shows +2.40V. Does it need to be calibrated or what is the cause of this?
Hope my english is good enough for you to understand the problem
//Robin
http://www.seeedstudio.com/wiki/DSO_Quad_Manual_(by_the_community)#Calibration
