reflective object sensors
Hi, I would like to know if anyone have experience using reflective object sensors, particularly OPB760T, http://datasheet.octopart.com/OPB760T-TT-datasheet-166455.pdf
i am trying to read the rpm from a shaft and was adviced to use this device however i do not know what the circuit should look like
thanks
thanks
I think pins 1 and 3 should be connected to ground. Pin 2 should have a resistor in series with it and Vdd (5V). I think a 330 ohm resistor would probably work okay.
Pin 5 should be connected to 5V. Pin 4 is then monitored to detect the dark lines. My guess is pin 4 will be high when there isn't anything to reflect the IR light and pin 4 will be low when there is something white in front of it. But it might be the other way around.
Maybe someone else who knows more about these will answer. I don't think you will hurt the sensor with above setup.
Duane
@ Leon, Yes thats the purpose of it. you normally do a small reflective strip on something that rotates and the device should be able to give a reading when connected to an oscilloscope. if you do have the circuit and can post it i would really appreciate your help!
rob
how did you estimate the 330 ohm please? thanks! rob
Honestly, it was just a guess based on previous experience with powering LEDs at 5V.
Here's the way to calculate it.
Resistance needed = voltage across resistor / current through resistor
= (total voltage - voltage drop across diode) / current
According to the data sheet the voltage drop from the diode is 1.8V.
It looks like the maximum current through the diode is 40mA.
If you want to use the maximum current you'd use:
(5.0V - 1.8V)/0.040A = 80 ohm
This absolute lowest resistance you should use at 5V.
If you want to reduce the current you'd increase the resistance. Let's say you want 10mA (something many microcontrollers can source directly).
3.2V/0.010A = 320 ohm
I used 330 ohm since it is a more common value of resistor.
3.2V/330ohm = 0.0097A
Using the 330 ohm resistor might depend on if 9.7mA makes the LED bright enough for your needs. I'd think it probably would.
If you don't need to control the LED from a microcontroller and can just leave it on all the time then a lower value resistor (say 100 ohm) would be fine. You might need to see what works the best. A very bright LED might (though I doubt it) trigger the receiver even when the over a dark area of the shaft.
I'd think the LED would last longer if you power it with less than 40mA.
If you're using a 3.3V microcontroller you need to make some changes. Let us know if you are.
Duane
R2 is needed if you have the open collector output version of this sensor. A resistor of 1K ohms or there about is a good choice.
