Sensor idea needed for deadbolt
Hey guys. Can anyone suggest a sensor idea that would detect the presence of a stainless deadbolt inside a receiver? There may be a little stray light inside the cavity that receives the deadbolt. I was thinking about the QTI sensor as an option, as it needs to be small. The sensor must be mounted inside the receiver with no mechanical parts. Any suggestions would be appreciated for something easy to do with a Prop.
The QTI has a daylight filter on it, so that might help with the stray light issue. Sounds like a reasonable idea to me.
Use the dead bolt as a ‘Gear tooth’. Mount a magnet and the Melexis 90217 Hall-Effect Sensor in the dead bold receiver.
http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/MLX90217.pdf
