Got a new Laptop Computer with Window 7 — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2011-06-20 18:24 in General Discussion
Is it hard to get use to using Window 7
as far as saving file and the like
My old laptop the screen when hay wire.........> took apart come to find out the plastic connector to the screen was torn on one of the four connector to LCD screen...> :depressed: no way to fix it now it just for parts
This computer was about 5 years old Compaq Presario
The new is the same but a lot newer and faster
    edited 2011-06-20 15:28
    no, 'cuz Win7 wuz my idea!
    edited 2011-06-20 17:39
    Sam . remove the old screen and use the laptop on a Ext Monotor as a Mini Computer or a slim server with a AMAZING built in back up power supply ..
    I call them slimtops
    peter
    Sam . remove the old screen and use the laptop on a Ext Monitor as a Mini Computer or a slim server with a AMAZING built in back up power supply ..
    I call them slim-tops
    peter
    I like the idea how ever
    I was NOT able to get the outside video to work so I parted it out
    The other problem I had with it was that it ran slow to very slow at time and would lock up at time
    I found out that this new Compaq Presario has Windows XP driver so If I have a hard time with Windows 7 I can us the fairly new hard drive that I had on the old hard drive
