Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
VGA_HiRes_Test newline scroll? — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
ProcessingData...
208
2011-06-16 11:16
edited 2011-06-16 20:08
in
Propeller 1
Has anyone written a newline function for the VGA_HiRes_Text object that scrolls the text on the screen when you reach the last row?
Cluso99
18,071
2011-06-16 18:07
edited 2011-06-16 18:07
For example code: See my 1pinTV code in the obex (under Debug 1pin TV & 1pin Keyboard). There is also VT100 code somewhere.
Ariba
2,697
2011-06-16 20:08
Here is a TV_Text/VGA_Text compatible layer for the HiRes_Text drivers.
This one is set for 80x40 characters, so also the HiRes drivers must use that settings.
But you can change the resolution in the constant section.
Andy
spin
spin
VGA_Text80.spin
3K
VGA_Text80.spin
3K
Sign In
Register
to comment.
Andy
